4 posts / 0 new
Last post
tonik's picture
Last seen: 3 years 3 weeks ago
Can't decide between two Led LG's, help needed.
I need of a advice. As i'm buying a new tv, I decided to go for LG because of his good picture and smart - 3D options. So here's the thing.
I'm looking at LG 42LA691S and LG 42LA667S. Here where I come from price of this two tv's are different as usual.
LG 42LA667S has a price tag about - 510 pounds. and
LG 42LA690S price tag is - 535 pounds.
On there official sites difference between this two are zero. Nothing separates this two tv's.
My question is what are real difference between this two tv's? Is the picture quality the same? every sugestion and opinion is welcome. have to clear which to buy, my deadline for buying is next month. haha Smile
axel1970's picture
RE: Can't decide between two Led LG's, help needed.
i dont really know any difference between the two ive bought a 47" lg led smart tv model no 47LN613V  and agree with you on pic quality only paid £499 now i think its gone up to £549 but if you can manage to go up to 47" i would bigger the better
Tarxman's picture
Last seen: 2 years 10 months ago
I hope I'm of some help. In Australia, the model numbers are slightly different to UK, but the difference between the 42LA6620 and the 42LA6910 is basically the latter has 4gb of memory built in for time shifting freeview.
tonik's picture
Thanks guys for the reply. As I was told today. Difference between this two tv's are only because 690S is a new model despite 667S. In other way everythong is the same. Even the glanc finish is the same. Only the 690S is a more metal designed.
I dont have room for a 47'' tv. so i'm looking for a 42''.
Theres a third solution, i could buy a 42 LA740S.
Log in to post comments
