£500 budget - Sony 32" or Toshiba 37"
7 replies [Last post]
pjboag
pjboag's picture
Would appreciate any advice on the best use of my budget of around £500.  I've come across a couple of bargains so far -  Sony's KDL 32V4000 (£379 from Amazon) or Toshiba's 37XV555 (£525 also from Amazon).  The set would sit a good 3 metres from our sofa so I would like to get a 37" but the Sonys at that size are outwith my budget.  Is the Tosh any good or should I settle for a smaller better screen?
Thanks in advance.
professorhat
professorhat's picture
Re: "500 budget - Sony 32" or Toshiba 37"
What about the Panasonic TH-37PX80 - available for £550 from Amazon - probably can be found even cheaper elsewhere if you hunt around a bit.
rewerb
rewerb's picture
professorhat:
Best buy 37" TV on this site. Laskys/Richer Sounds also do it for £549
pjboag
pjboag's picture
Thanks. I had thought about the Pana originally but was put off by the price.  But my budget is slowly creeping above the £500.  I can't help wondering about the lower resolution of this set though.  Will the 1024x720 really give a better picture than the Toshiba Full HD 1920x1080?
garethwd
garethwd's picture
Full 1080p sony 40" at sainburys for £599! sounds like a bargin to me
professorhat
pjboag:
Potentially - some of the Pioneer 720p sets have a much better picture than other cheaper 1080p sets at the same size. I can't comment on the Pana vs Tosh comparison though as haven't compared them.
sjared10
sjared10's picture
garethwd:
where did you see this prodct at sainsburys?i can can only find baked beans no tvs
__________________
Cool
Clare Newsome
Clare Newsome's picture
More in this thread
__________________
Group PR Manager - Computers Unlimited;
Former Group Editor of What Hi-Fi? Sound and Vision and Whathifi.com
Twitter: @ClareNewsome
