3D picture settings
2 replies [Last post]
richardw42
richardw42's picture
Which is generally regarded for the best 3d ?
Side by Side
Top & Bottom
Inverted side by side
Inverted top & bottom
Or is it a case of a film by film basis.
__________________
TV room : Samsung 60" plasma-ATV3, Denon DBP2012UD-Yamaha RXV3067-AVI ADM9RSS,MA RSW12,/Sonos ZP90 via optical, Sky+ HD & Sky Connector, PS3
HiFi : Sonos ZP90 - AVI ADM40
Bedrooms : 2 x Sonos Play 3
Ipad for Sonos & Spotify
SteveD
SteveD's picture
RE: 3D picture settings
I'm sorry to not be very helpful but I just use it in Auto mode.
I'll be interested also to see what others say.
__________________
MacBook Air (iTunes/BitPerfect) > Chord Company USB Silver Plus > MF V-Link II > Chord Optichord > Rega DAC > Tellerium Black I/C > Rega Brio-R > Tellerium Black S/C > Rega RS3s
iTouch > Graham Slee Novo > Grado SR80is
robjcooper
robjcooper's picture
Side by Side
Top & Bottom
All of the above formats will give you the same end result as there is fundamentally no difference between them. If you are watching sky3D or any other broadcast of 3D they will be using one of the above formats to encode the left eye/right eye into a single frame by 'squeezing' either vertically or horizontally the left eye and right eye information and recording them on one frame next to each other. Your TV then seperates and 'unsqueezes' this single frame to give you a full frame for each eye. However as each eye's image only contains half the 1920 horizontal or 1080 vertical pixel information it also means that you are getting half the resolution.
The best quality 3D is a FullHD 3D Bluray watched on a FullHD 3D active screen.
