9 posts / 0 new
Last post
sameersuleman's picture
Last seen: 1 year 2 months ago
3d passive/active glasses question.
Just wanted to find out if a tv came with passive glasses,can active glasses be used to view 3d content on the same tv?
My tv is LG47 LM620 T
Secondly to anyone out there knowledgeble with the settings on this tv-please let me have the best settings to get a crystal clear picture,i have a feeling my settings are not right because even on viewing a bluray disc i dont think am getting an optimum picture its not very clear,same content viewed on a diffrent tv gives much better quality picture.....yes amusing hdmi cable
Thanks in advance forany assistance.
b/r
bigboss's picture
Last seen: 2 days 10 hours ago
RE: 3d passive/active glasses question.
sameersuleman wrote:
No, active 3D glasses won't work on passive 3D TVs. Passive 3D glasses are extremely cheap in any case, far cheaper than active 3D glasses. They're the same ones you use at the cinema for 3D.
Check these:
http://www.whathifi.com/video/get-the-best-from-your-tv
http://www.thx.com/consumer/home-entertainment/home-theater/thx-optimizer/thx-optimizer-overview/
http://www.thx.com/consumer/home-entertainment/thx-certified-releases/
http://www.amazon.co.uk/SPEARSMUN-2-Spears-Munsil-Benchmark-Edition/dp/B00CKWI13O/ref=sr_1_1?ie=UTF8&qid=1374987101&sr=8-1&keywords=spears+munsil
Thanks big boss
bigboss's picture
CnoEvil's picture
One can't even take it for granted that the same Active Glasses will work between different brands that use this format.  :wall:
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
bigboss's picture
In 2011, the top manufacturers decided on a common standard. So hopefully it's not a problem anymore.
Also check this.
rocketrazor's picture
Last seen: 1 week 3 days ago
Also check this.
i couldn't get my 2012 panny active glasses to sync to a 2012 Samsung. I will try again though at some point as I might have been doing it wrong :oops:
CnoEvil's picture
Also check this.
Cheers BB.
hugfds's picture
Last seen: 3 years 6 months ago
maybe you should visit AVS,
Log in to post comments
