1.3b or 1.4??
Hi again all, long time no speak.
Probably a really daft question but am getting my first 3d read set in the bedroom a Panasonic TX-L32DT30B with a 3d blu ray player DMP-BDT110, what HDMI cable do I need, bit confused as 1.3b says 3d ready and so does 1.4. I can see 1.4 also has ethernet. How does this work and could I use it on thissetup??
Thanks in advance
TB
These are now the official designations for HDMI...
http://www.hdmi.org/manufacturer/hdmi_1_4/finding_right_cable.aspx
You will need 'High Speed' or 'High Speed With Ethernet' (if you want to network as well).
Sorry for duplicating Daveh's response. Not intentional.
Ironically, I don't think this fundamental message can be repeated too much! I would have posted the same.
- Login to post comments
Version numbers are marketing BS. There's only two types of HDMI, 'Standard' and 'High Speed'. You want High Speed cables for 3D.
http://www.hdmi.org/consumer/buying_guide.aspx
