1080@24p
9 replies [Last post]
kathryn1
kathryn1's picture
i have a panasonic 37lzd 80 ,i would like to know how do i know if its running at 24 fps when i watch a bluray the bluray says 24 fps but is the tv,running the same, does it do it automaticaly or do you have to switch it on.
D.J.KRIME
D.J.KRIME's picture
Re: 1080@24p
If your BD player is outputting at 24fps then you are watching a 24fps image as one beauty with a HDMI connection is that both bits of equipment "talk" to each other so when you initially set them up your BD player would automatically select athe highest resolution for your screen being 1080p and will happily output 24htz encoded BD software at a native 24FPS.
There will be a button on your Panasonic TV reomte that will display on screen your INPUT info showing you what resolution you image is set to.Geeked
__________________
My usefull posts Laughing How To Calibrate Your TV
STEVETYPER
STEVETYPER's picture
Re: 1080@24p
You will soon find that if you have the tv set at 24p "on"....... you will have terrible motion blurring...... same as my TX 37 LZD85, and BD 30 blu ray player. Panasonic recomends turning 24p off at tv if blurring is too bad........ but in my eyes , picture quality is not as good, and ruins HD effect.
__________________
Bedroom : Cyrus CD6se (smooth black), aCa7 pre amp, power/ Psx-r x 2, B+W CDM 1NT speakers, hark stand, VDH 102 mk111 interconnects, Chord company rumour 4 speaker cable, Grado sr 80 + AKG k701 headphones, Sky HD, Pioneer Bdp 320 Blu ray, Panasonic Tx-37 Lzd85 LCD tv, Logitech harmony 1000 remote (dead).... iPhone 4 32gb
lbafsaj
lbafsaj's picture
Re: 1080@24p
But does 24p really make a difference ?  My TV is 1080p but not 24p.  I do not notice any motion issues at all,  no matter what I watch.  is this a case of just not knowing what 24p looks like,  but I just don't see a reason to get a 24p TV when mine is fine.
STEVETYPER
Re: 1080@24p
To be honest, the 24p setting on my tv, is a complete waste of time.......it makes watching blu-ray films unbearable...... in fact i dont know how Panasonic get away with selling the tv's with it on ! Its so bad i have stopped buying and playing blu-ray films
__________________
ear
ear's picture
Re: 1080@24p
STEVETYPER but its possible to select 60 p on watching blu-ray isn't it? I also think its bad to watch 24p especially on big screens
__________________
Yamaha AX-397 + Yamaha NS-333;
HK 3390 + Tangent Millennium 200;
Cambridge Audio Sr10 +Cambridge audio  S30
alsina
alsina's picture
Re: 1080@24p
STEVETYPER:
There is not a '24p' setting on the Panasonic, so you cannot turn it on or off. What you are referring to is the '24p Film' setting which has a very misleading name. This is not turning 24p on or off, but instead switches on (or off) Panasonic's version of Sony's Motionflow which is a method of smoothing fast movement by adding artificial frames to the 24 frames coming from a Blu-ray. Whatever it is called and whatever make of set, this type of 'enhancement' tends to add odd artefacts to the picture and is better left turned off if you want to see the film as the director intended.
STEVETYPER
Re: 1080@24p
Alsina....... its just a shame i have to turn the 24p off, because the HD pic on blu-ray, def looks better with it switched on, until you get sudden movement, or a pattern in background, then things go wrong....... just seems a waste of time to me
__________________
STEVETYPER
Re: 1080@24p
EAR....... to be honest im getting totally confused with the whole 24p and 24 fps issue...... all i do know is, im not impressed with my Pan TX 37 lzd85 tv
__________________
ear
ear's picture
Re: 1080@24p
I dont have a blu-ray player yet, but when i go to the stores , sometimes I think I am viewing not a movie but a sequence of still photos that seem very unnatural to me. If I buy a blu-ray player I'm going to be sure there is an option on it so that i can select 60p instead of 24 p.The more choice the better.
__________________
