100Hz demo at SC
1 reply [Last post]
fooo
fooo's picture
I recently saw the Sony 100Hz motionflow demo at an SC. The one with the tabasco bottles and railings.
It convinced me I needed 100Hz LCD.
Then, walking next door to, they had a Philips 74 and 84 LCD unit, the same demo was running since the two shops are really one and the same - and the demo just did not look as good on the Philips - it was still blurry.
So - is this a canned demo tuned to work brilliantly on a Sony? Or is the Philips just not as good.
notherealakinan...
notherealakinanakamura's picture
Re: 100Hz demo at SC
I have never seen this demo but Sony does have the 'motion judder' nailed.But if you saw 200hz motionflow you then will convince yourself you need 200hz and so on.
That demo scene is an exception rather than typical scene you will encounter. But yes, it does proof  that judder is a problem if the eye can see.
