worth upgrading a Rega P1 ?
9 replies [Last post]
bobchiba
bobchiba's picture
Does anyone have any thoughts on whether or not it is worth upgrading a P1 with a glass platter and a better cartridge? I was thinking of a P2 ( or planar) but decided that might be better to hang on until I can afford a P/planar3 and spending a bit of cash on my P1 for the time being
__________________
sales
SSAV Oxford
fatboyslimfast
fatboyslimfast's picture
Re: worth upgrading a Rega P1 ?
Could be - depends on how much you want to spend really.
What cart have you got on there at the moment?
__________________
Sources: Technics SL1210Mk2 with Denon DL110/AT-95E, Mac Mini, Virgin V+.
Amplification: Cyrus 2.
Speakers: Mordaunt Short MS20i Pearls with Fisual Super Pearl 2.5mm cable.
Other kit: More than I should have. My loft is creaking.
bobchiba
bobchiba's picture
The ortofon om5e it came with, its quite a budget cart i think, I'd be looking to spend maybe £40 on a cart and £30 on an acrylic platter.
__________________
sales
SSAV Oxford
chebby
chebby's picture
bobchiba:
In which case spend the £75 on upgrading the OM stylus to OM10 for £45 (or OM20 for £100).
I doubt a glass or acrylic platter would make as much difference.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
one off
one off's picture
chebby
chebby's picture
one off:
or try the jico styluses
http://www.export-japan.com/marketing/stylus/product_info.php?cPath=12&products_id=726
Which Jico stylus replacements have you found to be as good (or better) as current manufacturer versions?
I am intrigued as there are only a few companies in Japan making profiled diamonds for styli. Namiki Precision Jewel Company, Nagaoka, Co. Ltd, Ichikawa Jewel Company (Jelco) and Ogura Jewel Industry Co. Ltd.
(Not sure that Ichikawa still do the styli any more though.)
__________________
one off
one off's picture
dont have the styluses to make those comparisons but the jico om30 i have is better than my om10
have a look theres heaps of info on jico on the web plus reviews
at $29 its worth a try anyway
chebby
chebby's picture
 But do they have the same profiles as their respective Ortofon OM counterparts?
If so then they are the bargain of the century and one has to ask why companies like Audio Technica and Sumiko and Denon and Ortofon and Lyra don't get their more expensive diamond profiles sourced from Jico instead of companies like Namiki.
__________________
gpi
gpi's picture
bobchiba:
Personally I wouldn't bother with the OM10 as it's not enough of an upgrade to make much difference. The big improvement with that range is the quality step up to the OM20, where you get a nude elliptical stylus. It makes all the difference and you should hear it.
one off
one off's picture
chebby:
check their website and also on the internet plenty of info there
i bought their om30 to see whether it was better than the om10 and it definitely is more than that i cant tell you
perhaps you could email them and ask
also its not worth going overboard for a p1 its good but you wouldnt drop a ferrari motor in your ford fiesta would you
