will the rega fono mini better the onboard phono stage of rotel ra04se?
Mon, Jul 23 2012, 6:14PM
Your inputs will be much appreciated.
Tue, Jul 24 2012, 8:23PM
#2
should i add a rega phono pre amp to my 04se or use its existing phono stage?
would there be significant improvements if i add a rega fono mini?
Your sig says you have a K2, I should try it with that first or even your 04se and see how it sounds. I have not heard either but doubt whether a fono mini would be much of an improvement.
Wed, Jul 25 2012, 7:50AM
#3
Yes the ra04se will be used for my second system which will definitely include a turntable too. Thanks for helping out.
- Login to post comments
Roksan kandy K2 amp, CA Azur 740c, Rega P3/24. Yamaha YP 700C, B&W CM1 & 685, Monitor Audio Bronze BR5, Victor QL Y5.
