Which turntable (Stanton vs. ProJect)?
4 replies [Last post]
tpjfin
tpjfin's picture
Hi all,
I'm getting a new turtable to replace my old one and basically I have two options.
1. ProJect Debut Carbon with Ortofon 2M Red
2. Standon STR8-150
I'm not a DJ (so maybe that Stanton one isn't really for me), but I will be using the turntable a lot. ProJect seems to be the better choice when it comes to sound quality and disc wear, but the Stanton TT has some things I'd really want (i.e. all the fancy automation).
Which one would you guys recommend, and why?
Thanks in advance! Smile
Petherick
Petherick's picture
RE: Which turntable (Stanton vs. ProJect)?
The Pro-ject.
Because of all the things the Stanton has that you dont need (i.e. all the fancy automation).
__________________
chebby
chebby's picture
tpjfin wrote:
Hi all,
2. Standon STR8-150
You have another option if you like the idea of the automation...
http://www.henleydesigns.co.uk/ui/support/support-product-details.aspx?ProductID=898
http://www.whathifi.com/news/audio-technicas-new-%C2%A3500-flagship-dj-turntable-on-sale-from-september
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
floyd droid
floyd droid's picture
2. Standon STR8-150
So you have a budget between 300-450 quid and have only 2 options !!.
Ye Gods i give up  doh!
Alears
Alears's picture
2. Standon STR8-150
I can understand floyd droid's frustration. Perhaps the OP could tell us why such a short list (I've never heard of the second choice), is this all he can audition locally or is there some other reason these are the only two choices he sees.
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Groove Anniversary/Tom Evans Vibe Preamp/Linear A power amp/Acoustic Zen Adagios/ Chord cables
