Which Graham Slee Phono Amp?
Thu, May 3 2012, 9:40AM
I have a DL110 cart which is a High output Moving Coil (HOMC) which puts out 1.6mV. I have been looking at getting a Graham Slee phono amp but don't know which type is suitable.
On the Graham Slee website it says all MM amps are suitable for HOMC but state a minimum output of 2mV is required from the cartridge and yet all Low output MC amps on the site say they can take a maximum input of 1mV? My DL110 falls in the middle at 1.6mV and appears to be incompatible with any Graham Slee amp.
Has anybody used a DL 110 cartridge with a Graham Slee amp and if so which one? Any comments appreciated.
Thanks.
Would suggest you have a look at Graham Slee's website and use their forums where you can ask Mr Slee direct
http://www.gspaudio.co.uk/
