14 posts / 0 new
Last post
drummerman's picture
Last seen: 1 day 17 hours ago
Warped records
I've read numerous threads/suggestions of how to apparently flatten warped records. - From putting them on the bottom of a stack to oven heating in a 'press' ... .
Would you put a valuable record in the oven??
I think it is almost impossible to flatten a warped record completely in a controlled way. However, I found a way that partially works with the most severe warps without destroying the subject.
If you apply warm (not hot) water to a record (or immerse it) it will warp/bend temporarely and then immediately return to its former shape. If you are quick enough and checked beforehand where the warp is you can apply hand/finger pressure and correct it.
Safer than an oven.
regards
plastic penguin's picture
Last seen: 2 days 16 hours ago
RE: Warped records
I wouldn't risk playing a warped record.
I once lent a ELO album to a friend, anyway, after about a month asked if he had finished with it. He revealed he put it in the attic, but he laid it flat instead of on its side and other boxes had fallen on top. Got the thing back home and it was pretty sorry state. I tried everything including using a iron (the album was well covered) but it was beyond playing.
Nah, I would ditch them.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
davidf's picture
Last seen: 1 day 13 hours ago
RE: Warped records
Would you actually play a record if it was that valuable? Smile
The Little Audio Company
audioquest / audio technica / bluesound / chord co / cornered audio / golden ear / harman / innuos / jbl / kef / moon / ophidian / primare / revel / svs
chebby's picture
Last seen: 9 hours 33 min ago
RE: Warped records
I've never owned a warped record.
Although i've seen a few in the past (in friend's collections).
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
RE: Warped records
Wow, so all yu guys only own completely flat records?!
I have old jazz, classical and even a couple of NOS records that are warped. Not to the extend that they upset the tonearm/cartridge but with slight warps in it nevertheless.
Kind of makes me wonder what constitutes a 'warp'.
They all play perfectly fine, it is probably more an aesthetic issue.
regards
RE: Warped records
regards
When the arm does a double flip with pike. Smile
RE: Warped records
Ah ok, I guess I'm fine then
regards
MakkaPakka's picture
Last seen: 1 year 3 weeks ago
RE: Warped records
According to this guide how to make a bowl, a record will be malleable at about 100 degrees.
http://www.wikihow.com/Make-Bowls-out-of-Vinyl-Records
My oven goes down to 60 so, in theory, I might be able to rescue a warped one.
floyd droid's picture
Last seen: 2 years 6 months ago
RE: Warped records
Furutech DF-2 yours for around 1700 spons. Methinks you are clever enough to google it without a tedious link.
Or send the really bad ones back and tell the seller to shove it where the sun dosnt shine.
For mild warps ,buy a ruddy clamp you tight beggar  ;).
RE: Warped records
Got a record clamp but it doesn't do to much for warps, very good though to dampen the record when used without tightening ... . Better would be one of those rings which weigh the record down at the outside but they cost a fortune.
regards
RE: Warped records
Plonk a small felt washer over yer spindle ,then clamp the baby down. Mibbe about 3-4mm thick  ;). Its worked for Mitchell for donkeys.
RE: Warped records
floyd droid wrote:
Plonk a small felt washer over yer spindle...
Ouch! sounds painful. :hand:
RE: Warped records
Didn't think of that, thanks pet
regards
RE: Warped records
:grin:
Log in to post comments
