Wall bracket for turntable
11 replies [Last post]
Charlie Jefferson
Charlie Jefferson's picture
I seem to recall this has recently been discussed, but I'll ask anyway, will a wall mounted turntable bracket have any detrimental effect on my sound?
My Roksan is currently in the flight path of a very active two year old, and another wannabee mite is on the way in February, so I need to find a permanent solution to keeping the deck safe and usable.
At present vinyl playing is a complete no go during daylight hours and only possible when the one man stampede is in bed.
Can anyone recommend a decent bracket for my purposes?
__________________
Roksan Caspian Pre amp, Caspian Mono Power amp x 2, NAD M51 DAC, B&W 805 Signature, Roksan Radius turntable, Denon-1713UD, MF phono & headphone amps, PS3, Mac/AE/Apple TV
nads
nads's picture
Re: Wall bracket for turntable
One of the project ones.
I use and like which ever one i have.
__________________
Not a HiFi Nut. Just has a pile of Nads.
PJPro
PJPro's picture
I seem to remember the Prof getting one although not for use with a turntable...it might have been a centre speaker support? Anyway, it was the sort of thing you're after.
Any luck, he'll see this post and provide a link.
__________________
My useful(?) What HiFi Forum threads can be found here.
pwiles1968
pwiles1968's picture
I was recommended in a post here http://community.whathifi.com/forums/t/286071.aspx, did not get appropriate WAF so I went down different route, but there are several wall mounts designes specifically for TT's
__________________
Stereo -1st Gen Apple TV with ATVFlash & 1TB HDD > Audiolab CDQ > Bel Canto Evo 2 > B&W 805s
nads
nads's picture
mine on the wall.
__________________
pwiles1968
nads:
mine on the wall.
 Cant work out what the smaller speakers are for do you have 2 separate systems there Stereo and AV?
__________________
nads
nads's picture
yes two separate systems.
__________________
professorhat
professorhat's picture
Yup, I got the Pro-Ject one that's in that other thread i.e. this one. As PJ says though, I got it for my centre speaker but it worked very well for that!
nads
nads's picture
professorhat:
Same as i am using for the turntable.
__________________
Henley
Henley's picture
Unfortunately the sub supplier that made the Pro-ject shelves has retired so we have been forced to remove them from sale. However, we are about to release 2 new models from one of our other manufacturers.
A wall support is probably the best isolation location for your turntable and is far less prone to little fingers than most.
The_Lhc
The_Lhc's picture
Just how far away would you say the TT needs to be from the speakers to stop feedback through the needle? My Debut II is only a few feet in front and to the side of my left speaker, but I've not noticed any issues as yet. I wanted a wall platform but the missus isn't too keen, she prefers everything on the rack.
__________________
No signature worth mentioning...
Henley
Henley's picture
At least a few feet if you can. Try to keep the turntable out of the line of fire if at all possible.
