Turntable setup for under £250
5 replies [Last post]
metalmaniac248
metalmaniac248's picture
hi
im lookin to get a turntable setup for under £250
now obviously that means gettin a turntable, but iv heard that if i want good sound il need a phono preamp, so a decent setup with a turntable and phono preamp fro under 250
dont really know what im lookin at here. :S
thanks
John Duncan
John Duncan's picture
Online
Re: Turntable setup for under "250
You have an amp and speakers already, I take it? If so, what are they?
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
chebby
chebby's picture
Online
Rega P1 turntable (comes with fitted catridge)  £194
Rega Fono-Mini MM phono stage.  £55
Total £249
Prices correct from Rega's Sept 2009 pricelist.
This will all take about 2 minutes to set up. The cartridge is already fitted and aligned so no 'faffing'.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
pwiles1968
pwiles1968's picture
Online
My ProJect Genie3 & Phono Box MkII were about £240 that leaves you enough change for a Granite Chopping board from Wilco to put it on  - http://community.whathifi.com/forums/t/309815.aspx
__________________
Stereo -1st Gen Apple TV with ATVFlash & 1TB HDD > Audiolab CDQ > Bel Canto Evo 2 > B&W 805s
metalmaniac248
rite erm if heard about the pro-ject genie, i shall check the rega's out,
is a phono pre-amp absolutely necessary?
and i currently have a cabridge audio azur 540R av receiver (Ver. 2) as my amp and thats connected to some TDL studio 10's
chebby
chebby's picture
Online
metalmaniac248:
In this case, yes it is necessary.  The back of your receiver does not have a dedicated phono (turntable) input
__________________
