3 posts / 0 new
Last post
seasonsdownfall's picture
Last seen: 1 year 2 months ago
Turntable needs repairing. Cartidge wires...
hi guys,
I am upgrading my cartdige and whilst removing the old cartidge two of the cartidge clips came off the wires.
I don't know how confident i feel re soldering them back on? Do you know where is best to get this fixed? It would be a simple job, but its obviously very delicate.
any help would be appreciated,
for reference deck is - project essential, removed current cartidge which was an OM series, and upgrading with the ortofon 2m red.
Thanks!
toyota man's picture
Last seen: 1 month 3 weeks ago
RE: Turntable needs repairing. Cartidge wires...
Maplins sell a little rig which has crocodile clips which you use to hold everything in place which makes life a bit easyer when soldering be very care full when stripping the insulation from the cables so as not to pull cables out of arm or brake them make sure you tin both the cable and the clips
as this will make it a bit easyer good luck
Musical Fidelity M6500i, Musical Fidelity M6 CDP, Musical Fidelity Encore Connect, ATC SCM 40s, Cord Chameleon plus XLRs, Tellurium Q Black speaker cables.
Thanks very much for the response!
Yeah, they are very thin, i've read to use a razor to strip the wires? I should have just left the cartridge and simply upgraded stylus :wall: ... but hey, good excuse now!
Log in to post comments
