Turntable connected to denon 2311 amp?
Wed, May 11 2011, 12:05PM
Is this possible? Would the results be better than cd's, data files etc?
Wed, May 11 2011, 12:13PM
#2
The AVR-2311 doesn't have a built-in phono stage, so you'd either have to use a turntable with such a stage built-in, or an external phono stage between turntable and amp. After that it would act like any other line-in source, the quality being dependent on the performance of the turntable and phono stage employed.
Sun, Apr 22 2012, 7:26PM
#3
Would the rega Rp1 & rega fono mini a2d be a compatible set up with the denon?
- Login to post comments
Yes but you'll need a phono stage. I can't remember if the 2311 has one built in but if it doesn't you'll need to buy one, or a turntable that includes one (some Pro-Ject TTs do, don't about any others).
that depends entirely on how much you're prepared to spend on the TT, phono stage etc.
No signature worth mentioning...
