Tonearm re-wiring
4 replies [Last post]
The_Lhc
The_Lhc's picture
Anyone got an experience with re-wiring tonearms?
My other half has an old BSR Ultra all-in-one TT and someone/thing has chomped through the tonearm wiring just beyond the end of the arm, so I need to replace it.
I'm not talking about just replacing the short headshell leads, I need to replace the entire wire from the back of the cartridge (including the pins, ideally pre-soldered), all the way through to the point it's soldered onto the terminals inside the unit under the TT (so that end needs to be bare wire), probably about a metre or so. This is a 5 wire job, it appears to include an earth wire of some sort.
I've tried a bit of googlage but all I'm getting is Rega replacing wiring, which is no good and I'm not spending hundreds on it, I don't particularly want to even spend 20 quid if I'm honest, I'm just trying to get it going again so she can ruin some records on it and stop bothering me about it (she has a Project Debut II, so I don't know what the fuss is about really).
Any ideas?
__________________
No signature worth mentioning...
Alears
Alears's picture
RE: Tonearm re-wiring
As you are probably aware by now the complete rewire of this beasty is never going to be cost-effective, even if you can perform the operation yourself. Crying
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Groove Anniversary/Tom Evans Vibe Preamp/Linear A power amp/Acoustic Zen Adagios/ Chord cables
Paul.
Paul.'s picture
Apparently, you can open up the chord from an old computer mouse.  It has four very thin cables of high quality copper, and supposidly sounds pretty good.  Nice and low mass.  I wouldn't usually sudgest such a thing on this forum for fear of retribution, but you don't sound too attached to the TT!
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
The_Lhc
The_Lhc's picture
Yes I've seen someone mention the mouse cable idea before, I do need five cables though and I think I've only got one old mouse lying around...
__________________
CJSF
CJSF's picture
Here go The_Lhc, rewiring kit: eBay no. 181043519393
Wont break the bank, cardas type I believe?  I looked here when I was considering a re wire or new arm?
CJSF
__________________
Rega P5/PB700 (upgraded main bearing, white drive belt), Sumiko Celebration Pearwood Signature cartridge, Carver MCt, Croft Integrated Valve hybrid amp, PMC LB1's on Foundation Designer Stands, Rega Apollo CDp. Cables: speaker, Linn K20, Interconnect, Foundation Audio Special.
