Thorens TD 160 Mk 11 connecting to a Pioneer XC L7 receiver
Sun, Jan 30 2011, 11:52PM
Hi all, just joined the forum. I have a 30-year old Thorens TD 160 Mk 11 with a Goldring Elektra cartridge and, due to moving some furniture around, would like to connect it to a Pioneer XC-L7 receiver but the volume is barely audible. Anyone know what's wrong?
I used to enjoy messing around with hi-fi but now I just want to hear my old albums.
- Login to post comments
Hiya, and welcome to the forum.
Are you plugging your turntable into an "aux" and not "phono" input?
If so, and your XC-L7 doesn't have a input marked "phono", you will need to purchase a separate phono stage to go inbetween the Thorens and your Pioneer. This is because the output from a MM cartridge like the Elektra is around 1/200th of that of say a CD player. Most micro and mini systems won't have a phono stage as standard.
These can be bought from around £20, all they way up into the thousands. For what you have, I would suggest that the Vivanco phono preamp from Richer Sounds at £20 should do the job fine.
http://www.richersounds.com/product/phono-pre-amps/vivanco/pa111/viva-pa...
Hope this helps...
Sources: Technics SL1210Mk2 with Denon DL110/AT-95E, Mac Mini, Virgin V+.
Amplification: Cyrus 2.
Speakers: Mordaunt Short MS20i Pearls with Fisual Super Pearl 2.5mm cable.
Other kit: More than I should have. My loft is creaking.
