Thinking of plonking my ProJect Debut Carbon on this?
22 replies [Last post]
gooner26's picture
Will it be ok for this? Do not want anything bolted to my bedroom wall, just something sturdy, simple and neat!
Best
Danny
floyd droid's picture
Online
RE: Thinking of plonking my ProJect Debut Carbon on this?
Looks a teeny weeny bit on the small side mate. Try again as there is nowt showing in the foatie dpt .
gooner26's picture
sorry, totally messed up there!
gooner26's picture
The pic shows first of all then doesn't show after I've sent it. Never mind.
This is the best i can do I'm afraid.
http://store.atacama-audio.co.uk/p/equinox-hi-fi-single-shelf-180mm
chebby's picture
Online
__________________
Marantz M-CR603 • Rega R3 loudspeakers • AirPlay • Apple iPad Mini • Apple iPhone 5 • Apple iMac • Apple AirPort Extreme 802.11N • Humax HDR-Fox T2 • Panasonic TX-L32D25B • Sony BDP-S390
gooner26's picture
Thanks chebby.
The Atacama one i have my eye on is £85
do i really need an ultra stable support? Will a cheap  small table really do?
regards
danny
chebby's picture
Online
gooner26 wrote:
Thanks chebby.
Yes. Especially the second one. Very solid and stable. (And the Atacama only has three legs which is hardly stable.)
Purpose built AV/hi-fi stands are mostly hokum and always overpriced.
__________________
gooner26's picture
Well that's more money saved. Thanks for that chebby!
Im blind buying my first ever Turntable to plug into my M80. I've heard from a couple of Meridian experts the M80 will not let me down. It's incredible with a Squeezebox Touch so expecting great things hopefully!
Just purchased my first ever Vinyl to, The National, Trouble will find me, Jimi Hendrix, Axis bold as love & Wild Nothing, Nocturne
jcarruthers's picture
Hmmmm three legs are more stable than four — how many wobbly three legged stools have you ever come across compared to four legged tables?
Having said this — I do plan to buy one of those Ikea tables to put my hifi one — my amp and DAC will fit perfectly on the shelf underneath
__________________
Rega RP6 w/ Dynavector 10X5 & Gus's Subplatter & ME Technoweight & ME VTA adjuster | Rega DAC | Rega Brio-R | B&W 601 S3 | Rega Ear Mk2 | Grado SR60
Chord CrimsonPlus | Audioquest FLX/SLiP 14/4
Arcam rPAC | AKG K550
stevebrock's picture
yeah like how the EDITED 'the bass tightens up with this rack'
what a load of rubbish ffs
Mind you Hifi Racks Podium are reeeaally nice Smile
__________________
Icon Audio ST40 III / KT88, Rega Apollo R, DAC, RS3
Rega RP6, Nagaoka MP-200, White Belt, Michell Tecnoweight, Rega Fono MM
Rega Quattro, Couple 1 & 2
CnoEvil's picture
IME. A rack "can" make a difference.
IE. Things like:
- Material/s that it's made of
- The design
- How effectively it isolates the components on it from vibration
- Whether it lets resonance within components drain out
- How solid it is
Here is Lavardin's take on it (What is the best rack to put an amplifier): http://www.lavardin.com/lavardin-faqE.html#support
Then again, I could be completely wrong.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
Captain Duff's picture
I disagree with Chebby on this one. Yes, over-priced racks for digital componants can be questioned (do 1's and 0's really care?), but if ever there was a need to isolate a piece of hifi equipment from either vibrations through the floor from the speakers, or footfall on wooden sprung floors, it is a TT. Plus of course better quality racks or shelves allow far easier levelling, that again is vital for TT's.
The other factor here is that cheap solid plinth TT designs such as Rega (sorry!) don't have the benefit of a sprung sub-chassis (like, for example, Thorens and Linn decks) to absorb many of the outside vibrations that are so easy to trransmit through a stylus and back out into the room. In other words unless you properly isolate your deck you risk getting a rather muddy sound.
The best solution for a Rega, particularly with wooden floors, is a wall shelf (assuming the wall is solid and not modern flimsy vibrating internal plasterboard over a wooden frame). Failing that a table that allows both levelling (adjustable spikes, like on floorstanding speakers) and a de-coupling shelf system is best. You can often get s/h bargains on ebay, and for a vinyl centered system using a solid plinth deck like a Rega it is probably the best upgrade you will ever make.
Oh, and incidentally, a 3 legged design is in theory inherently better as the problem with four legs is unless you can carefully adjust them you risk having a rocking motion (sometimes a very small one, but potentially one that will affect the sound of a TT) where two of the four legs make better contact on an uneven floor or where the bottom spikes are poorly adjusted (same thing happens with speakers). It is for that reason that a lot of isolation platforms come with 3 feet or spikes under them rather than 4.
__________________
Thorens 166 BC MkVI turntable, Origin Live Alliance tonearm, Goldring 2200 cartridge; Opera Consonance 120 Linear CD player; Denon DNP-720AE media player; Sugden Mystro amplifier; MS Aviano 8 speakers.
chebby's picture
Online
The OP already stated that any wall mounting was a no-no...
"Do not want anything bolted to my bedroom wall"
He proposed to use a single 180mm level from an Atacama rack unit instead...
... presumably on the floor or a piece of furniture.
A sturdy, solid wood table (500mm height), like the one I suggested, with a shelf to brace it seemed far better. (And levelling is not a problem if you have solid wood legs to fit something like these ball and socket, levelling/locking feet...
__________________
Chebby — where do you find those feet?
__________________
chebby's picture
Online
http://www.arnott-group.co.uk/adjustable_feet/
__________________
Al ears's picture
Personally I find a folded beer mat is perfectly adequate for levelling. Smile
It's about time HiFi Racks did  three-legged design.
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 dac/Tom Evans Groove Anniversary phono amp/Tom Evans Vibe preamp/Linear A power amp/Acoustic Zen Adagios/Chord cables/Oppo 105EU.
