23 posts / 0 new
Last post
plastic penguin's picture
Last seen: 1 week 19 hours ago
Think my stylus is on its way out.
The sound doesn't quite have the clarity from a few weeks ago. Tried re-weighting the cart and carried out all relevant checks. The stylus looks okay to the naked eye but I have had the cart 8-years.
Will be changing the TT over the next few months so looking for a interim cart to fit the Pro-ject. Reluctant to spend £150 on a ClearAudio Concept cart just in case I plump for the ClearAudio TT, which has the cart fitted. I know the Nagos have a good following on here. My clear fav, due to personal experience, is Goldring. How do those two compare soundwise? (Nago and Goldring)
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
stevebrock's picture
Last seen: 6 days 23 hours ago
RE: Think my stylus is on its way out.
plastic penguin wrote:
The sound doesn't quite have the clarity from a few weeks ago. Tried re-weighting the cart and carried out all relevant checks. The stylus looks okay to the naked eye but I have had the cart 8-years. Will be changing the TT over the next few months so looking for a interim cart to fit the Pro-ject. Reluctant to spend £150 on a ClearAudio Concept cart just in case I plump for the ClearAudio TT, which has the cart fitted. I know the Nagos have a good following on here. My clear fav, due to personal experience, is Goldring. How do those two compare soundwise? (Nago and Goldring)
PP,
All I can say is the Nag MP110 will see you through until you get a Clearaudio TT - then keep the Nag as a spare.
You never know you may prefer the Nag over the Clearaudio.
If you are definately not upgrading your TT then the logical choices would be Goldring 1042, Dyn 10x5 & Nagaoka MP200 - all good MMs
The Dyn is a bit more forward over the Nag, but all depends on rest of your system.
I havent heard a Goldring but the Nag is warm side of Neutral IMO
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
chebby's picture
Last seen: 3 hours 54 min ago
...the Nagos have a good following on here. My clear fav, due to personal experience, is Goldring. How do those two compare soundwise? (Nago and Goldring
The Goldring 2200 and 2300 are both made by Nagaoka.
Not that that necessarily means they'll sound like Nagaoka cartridges.  Just interesting.
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
chebby's picture
The only Goldring I can personally recommend (from 11 years experience of it*) is the 1042.
Bit pricey nowadays.
*It was well used and I got through two stylus replacements in those 11 years between 1996 and 2007.
Umm... didn't know that. Very intersting.
If I was keeping the Pro-ject long-term I wouldn't hesitate to get another ClearAudio but...
One other question: With a new cart do you get the screws or would I have to source them separately?
PP,
Ta.
I wouldn't invest in a Dyn cart on a £200 TT. TBH, the ClearAudio was an overkill. Hindsight is a wonderful thing.
chebby's picture
Most come with screws but they have a habit of providing the softer aluminium ones. (Non magnetic and cheap I suppose.)
Better to use stainless steel fittings with hex bolts ...
Stainless steel is harder and also non-magnetic.
Just had a quick shufti and the Nag 110 and Goldrings are above £100. Ortofon 2M red is about £80. If the other two are over £100 might as well get another ClearAudio.
PP,
I've ordered Ortofon 2M. Should be with me early next week.
When I get the new TT the Nagos will be at the top of audition list, but just an interim cart it's pointless spending more.
Ta all.
It's arrived.  \0/
The fun part will come over the next couple of days. Haven't fitted a cart for close on 20-years.
Henley's picture
Last seen: 1 year 6 months ago
Just use the bolts supplied.  They are designed to be finger tight only.
Do NOT crank the cartridge into the headshell.
UK distributors for Pro-Ject, Ortofon, Roksan, Unison Research, Lehmann and Reloop
Here to help.
chebby's picture
It's arrived.  \0/
So as you have the Project alignment protractor in your box of bits (or the TT box) then it'll be fine. I've done lots of them in the past and you never forget.
It's arrived.  \0/
Ta.
That's why I said it'll take a couple of days, cause the box is languishing somewhere in the attic.
Think my cart is on its way out.
It was strangely easy, albeit a little fiddly, to fit the new cart. First impressions:
Sounds okay, not the shortfall initially thought. For sure the ClearAudio does uncover the subtle detail throughout the frequency better and the bass is better defined than the Ortofon. Also noticed the HFs, when cranked up doesn't quite have the coherence of the ClearAudio, otherwise, for the price the Ortofon does a good job.
Think with a better TT the ClearAudio would really show its stripes, but on a budget jobbie like mine the Ortofon is adequate.
Since the ears have adjusted
Since the ears have adjusted to the new cart, the overall soundstage has been missing something, although couldn't quite put my finger on it. Mrs. P said it has lost a little intimacy. We're not talking night and day, and highlights the good and bad of a budget TT.
The ClearAudio cart was really the icing on the (modest) cake. That icing is now depleted.
Any suggestions without spending fortunes?
Pages
Log in to post comments
