2 posts / 0 new
Last post
Lewis_Digital's picture
Last seen: 3 years 2 weeks ago
Speakers - Newbie Question
I am so sorry for the totally newbie question - go easy on me
http://i49.photobucket.com/albums/f272/KazeUK/photo.jpg
Can you please advise if there is a certain type of speaker I need to buy for the above amp/connection type? Is it literally any sort of speaker and even if they have banana plug/jacks on, strip them off and expose the wire, and connect that way?
Most appreciated
Lewis
The_Lhc's picture
Last seen: 3 months 1 week ago
Those are standard speaker
Those are standard speaker terminals, you can use any speaker with them.
Speakers don't come with cable or banana plugs by the way, you have to buy those separately. If you want to use bananas you need to remove the plastic plugs from the centre of the terminals, just pop them out with your nails (if you've got any) or a small screw driver (unplug the amp before you do that).
Log in to post comments
