SANSUI FR-D35 vs PROJECT DEBUT SE3 TURNTABLE PIANO BLACK - DEBUT SE3
Mon, Sep 19 2011, 3:18PM
As you can see I have gone and bought a new turntable of which I'm very pleased with. But what about my old Sansui ? I was under the impression that Direct Drive is better. Should I be able to get parts for it still? Is it still a good turntable? Should I keep it for my 2nd system (must then get a Pre-Amp, and speakers)
I'm open to all suggestions about this topic.
- Login to post comments
The simple answer seems to me that in your main system you should use the TT you most like the sound of.
DD vs belt-drive...oh dear I can hear the worm-can breaking open from here. Basically both methods have their merits and drawbacks. One TT certainly won't inherrently sound better than another TT purely because of the method it uses to rotate the platter and nothing else. There are far more factors than that. But expect to find an equal number of fanboys on both sides of the equation, each of whom will swear the other side is a fool.
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
