Review of Rondo Red
30 replies [Last post]
skularatna
skularatna's picture
I've found this online:
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/2755 a considerably good price for a moving coil? But I cant find the review on this site?
Can someone point me to the lnk. Also my preamp is a cambridge Azur 640P. If I were to get this MC would my Azur be sufficient. It can switch between MM and MC
floyd droid
floyd droid's picture
Re: Review of Rondo Red
Google rondo red review mate, its out there. I would web trawl harder if i were you in regards to the price Wink
skularatna
The cheapest ive found is £359 but will look for cheaper, only thing is can I use it with my Project Genie III also will my Azur 640P switched to MC have enough voltage and load impedance to handle this ?
floyd droid
Its just registered what deck you have. In my honest opinion mate just get a 2m red, that will do ya. Spend the rest on albums.
skularatna
Appreciate the feedback I heard hte moving coil picks up detail not heard in MM and i have a pretty good ear playing live music and all and Ive have a lot of jazz and classical vinyl and there is certain lack, i.e i can hear some detail that i hear in live performances. I can afford upto £400 and the rondo red is an entry level MC.  ?
floyd droid
Its your money my friend, and there are loads of carts out there that will bladder the rondo at or around that price point, but you will not be getting the best out of it with your setup. Big Smile
Can a diplomat step in here please.
chebby
chebby's picture
Online
A £400 MC on a £150 turntable is a bit a__ about face.
You will get better results with a £150 cartridge on a £400 turntable.
A bit like why a humble Ford 1600CC engine works well in a Caterham 7 whereas a Ferrari engine dropped into a Ford Focus would be a disaster.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Apple iPad Mini • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
John Duncan
John Duncan's picture
Here I am! Putting a Rondo Red on a Genie would be like putting Bugatti Veyron tyres on a 2CV, and wondering why it was still sh-t at going round corners.
A moving coil cartridge is a delicate instrument, and needs a stable platform for it to give of its best. Bearing in mind that I once gave a presentation on the physics of turntables in which I equated the job of a turntable's cartridge to trying to cut your fingernails with a chainsaw stuck on the end of twenty drinking straws whilst standing on a washing machine on spin cycle, might I respectfully suggest that a Genie, whilst fabulous for what it costs, is not that stable platform.
__________________
Cambridge Audio StreamMagic 6  |  751BD  |  651A  |  PMC DB1i | A secret shiny box | Sonos Play:3
Moderator. mail: john.duncan.whf at the mail of g dot com
John Duncan
(ooo jinx on the car analogies chebs)
__________________
chebby
chebby's picture
Online
I did a presentation on cartridges once as well!
I equated it to superglueing a diamond the size of the Empire State building upside down to a cantilever made of 10 Supertanker hulls welded end to end and scraping the whole thing down Cheddar Gorge at mach 3.
__________________
John Duncan
chebby:
Which is probably more accurate, technically, but I could only get hold of a chainsaw at short notice.
__________________
skularatna
I see your point my friend, I guess i was being overly keen. So What would be the best cartdige to go form. Are there moving coils in the range of £150 or a bit more?  that would work well with my genie?
skularatna
or should I stick with MM? I'm just not overly keen with the cartridge supplied. Certain records like Queen absolute greats seem to lack detail in the vocals?
John Duncan
Stick with moving magnet. And I'd second the suggestion above that a 2M Red (£50 or so) is about the limit of what I'd use on a Genie. if you want to use a moving coil cartridge, I'd say you need to upgrade your turntable to something like a Rega P3-24 or Pro-ject RPM5.2.
__________________
chebby
chebby's picture
Online
Going from your previous posts (and this one) you have a budget af around £400 for a cartridge and a Genie III that is only a week or so old.
Is it possible to go back to your turntable 'purveyor' and exchange the Genie for a £400 turntable and pay the cash difference?
If so, then (in theory) you will have enough left over for a fine MM cartridge like the Ortofon 2M Blue.
__________________
skularatna
Thanks. Maybe some day ill be able to afford a turntable with MC. 2M it is . Can you confirm that it is worth it. The ortofon site says that it will pickup detail in the records.
