9 posts / 0 new
Last post
cisamcgu's picture
Last seen: 11 months 3 days ago
Replacing a P77 A&R on a Rega Planar 3
Hi all,
I have an old Rega planar 3, probably about 30 years old and the cartridge/stylus is shot. Yesterday the TT suddenly sounded dreadful, I lifted the arm, checked the stylus for dust/debris and was a little shocked when I couldn't see the stylus tip - I'm not sure if it has worn away, broken off or what - but as far as I can see it has gone  :O (I'll see if I can get a pucture)
Well, I presume I need a new one and the question is - do I try and get the stylus fixed or splash out on a new cartrige, and if so which one ?
It looks as if I can get a replacement for £31.50 from http://www.musonic.co.uk/stylus-styli-needles-ar-c-1_65.html
But would I be better off getting a new one ? I know they will cost £75+ but is it worth it ? I wouldn't want to spend more than about £100 though
Any thoughts ?
Andrew
Lost Angeles's picture
Last seen: 1 week 3 days ago
RE: Replacing a P77 A&R on a Rega Planar 3
Steve983 is buying a new stylus for his RP2 (check this thread out) lets hope he comes back with some feedback and makes it easier for you to decide.
<p>Michell Orbe SE. Origin Live Illustrious 2/3. Transfiguration Axia S. Roksan amps. Dali Epicon 2 speakers.</p>
cisamcgu's picture
Thanks, I shall watch that thread with interest. Although, after peering at the stylus with a magnifying glass night night, I think I was wrong with my orginal assumption that the tip had gone, but rather it is just very small compared to the stylus on an old Pioneer PL-12 that I have at the moment.  The sound it makes is definately not as clear as it was a few days ago, so something has happened.
I shall hold my powder dry for the moment, but I am tempted by an ortofon  M2 Red at about £85.
You might be better off with a Nagaoka, seems to be the most recommended on here.
GeoffreyW's picture
Last seen: 1 day 9 hours ago
I also have a Planar 3, with the S-shaped R200 arm, and have just replaced my old cartridge for a Nagaoka MP110, and I'm very happy with it.  They're around £85. Good luck.
Rega RP3  Nagaoka MP110  CA640P  NaimUniti   NAC A4  Royd Doublets  B&O H6  Alessandro MS1   Panasonic TX-P42G15B   Panasonic DMR-BWT720  Humax HDR-1100S
cisamcgu's picture
Still haven't made my mind up
Still haven't made my mind up Smile £31.50 for a new stylus or about £85 for a Nagaoka MP100 .. choices .. choices .. or perhaps a REGA Bias-2 ?
Andrew
Al ears's picture
Last seen: 5 days 14 hours ago
If it's that old...
In my humble opinion if your P77 is as old as the deck, and it probably is I'd guess, then you would be much better off replacing the whole thing right now. Bite the bullet and buy a new Nagaoka MP110 as recommended in previous posts.
This is a much better all-round cartridge than the P77 and you are only likely to encounter more problems in the future if you purely replace the stylus on the A&R.
Also I'd suggest you forget the Rega Bias......
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
cisamcgu's picture
Many thanks, I shall visit my
Many thanks, I shall visit my local hifi shop at the weekend and see what they have
stevebrock's picture
Last seen: 4 days 11 hours ago
I will echo Al ears opinion,
I will echo Al ears opinion, the Bias 2 is poor IMO, save the £35 towards a Nagaoka MP110 - the best cartridge IMO and wipes the floor with the Rega Elys 2 as well as the Bias 2.
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
Log in to post comments
