13 posts / 0 new
Last post
geoffreyc's picture
Last seen: 11 months 2 days ago
Rega RP3, Ortofon 2M Red Cartridge & Hum question
Looking to get the RP3/Ortofon 2M Red combo soon. Will be using with my Yamaha RX-A2010 receiver.
I understand the Rega has no earth lead (done internally inside arm?) and have read  reports of some owners experiencing hum.
Any owners of the RP3 - which I thought sounded fantastic during a demo recently care to give me their opinions/advice?
stevebrock's picture
Last seen: 1 day 10 hours ago
RE: Rega RP3, Ortofon 2M Red Cartridge & Hum question
What hum? No Hum on my RP3 or RP6 dont worry about it!
More importantly I think you will need a phono stage! Get the Rega fono mini to get your started!
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
Hi-FiOutlaw's picture
Last seen: 1 month 1 week ago
There is no hum in my RP3!
Rega RP6/Goldring Elite MC>Clearaudio Basic Plus
Synology NAS>Auralic Vega>Pathos Classic One MKIII>Dynaudio X12
drummerman's picture
Last seen: 2 days 9 hours ago
Nop, that upgrade would cost extra, with the belt, the subplatter, the counter weight ... . At this level they will also include a wobble Wink
regards
DM,
Get you facts right! Only the RP6 model comes with the wobble, which can be exchanged for a full-price non-wobble RP6 at no extra cost!
regards
ah! That is Steve department, not mine... Wink
apparently LP12's wobble too...........shocker!
geoffreyc's picture
The Yamaha does have quite a decent MM phono stage to begin with actually.
alchemist 1's picture
Last seen: 2 weeks 3 hours ago
regards
    DRAT ! Too late.............:rofl:
iMark's picture
Last seen: 2 weeks 3 days ago
That sounds like an earthing problem. My Pro-Ject 1Xpression III came with an earthing cable which I connect to my Denon stereo receiver. Without the cable, there is huge hum.
Pro-Ject 1Xperience Comfort (OM 2Red), Yahama R-N602, Sony UHP-H1, Sony TV, Humax DVR, Infinity Overture 1 speakers. Range from very cheap to expensive cables.
Rega decks come with earthing cable in the arm, Rega decks DO NOT hum
jcarruthers's picture
Last seen: 3 years 2 weeks ago
I had the OM2 Red on my RP6 and there was no hum
gwynne61's picture
Last seen: 5 hours 7 min ago
My P3-24 didn't give any hum until I installed the Rega power supply after which a low level hum was noticable and was quite annoying. It was easily solved by running a short earth wire from the casing of the power supply to the amplifiers ground.
It hasn't hummed since, the platter doesn't wobble either  ROFL
Log in to post comments
