Rega RP3 Dimensions
Theres a Gremlin in the system.........................
You shouldn't need to worry about that because if lid is anything like the Planar 3 then the lid comes completely off.
It is best operated without the lid attached anyway.
I was worried that one of our cats might jump on it while its playing.
If its not hinged I can make the shelf smaller, which will be better for aesthetics.
hi
With the lid open is 43 cm, 1.7" foot
Best REGArds
So does that mean its hinged Hi-fiOutlaw?
Your a topman Hi-fiOutlaw, I can get that sorted tomorrow. I've made some speakers stands, so just need do get shelf sorted now.
You're welcome!
And thanks!
Thats why this Forum is here! To help each other!
Best REGArds
- Login to post comments
TRY AGAIN
Hi There
I am building a shelf for the Rega RP3 and have not got it yet but I need to know how much space is needed
at the back to open lid?
The dimension of the player are 450mm x 360mm according to WHF, just need the measurement for extra space needed at the back to open lid.
Thanks in advance
Rega Brio r, Rega Dac, Rega ear headphone amp, B&W 685 speakers, apple airport express-toslink.
various quality cable What HiFi awards.
