Rega P5 entry level cartridge: Goldring 2100 or Elys2
2 replies [Last post]
NeoVibe
NeoVibe's picture
Hi all,
Getting my first turntable, a discounted Rega P5 (for the price of an RP3 Smile) but with no cartridge, so I need to pick one and your help is most welcome.
I would like to consider only Goldring and Rega because those are the ones available locally. This being my first turntable I am thinking of starting slowly with entry level cartridge/phono-stage and then upgrade the rig. If I decide to continue in the vinyl path, on the long run I will upgrade cartridge, phono-stage and PSU.
So that said my evident choices would be Goldring 2100 or Elys2 for about the same price. I don't prefer 'warmer' or 'colder' cartridges - I like my sources neutral and let speakers/amp tailor the character to my liking.
- which would you recommend for a P5, Goldring 2100 or Elys2?
- ...or do you think I am completely wasting my time using one of these cartridges in a P5, and should instead go straight for, say, a Goldring 1012gx ?
Thank you for your help and wish me good luck in the world of the grooves Smile
mitch65
mitch65's picture
RE: Rega P5 entry level cartridge: Goldring 2100 or Elys2
Nice choice!
I have been tempted by this deal myself but decided I must use self control Smile Smile
I have used the Elys 2 in the past and liked it and the Goldring 1042. I cannot comment on the 2100 but have heard that it's a bit marmite (you either love it or hate it) which cannot be said for the 1012 ot 1042 which seem to be universally praised. If it was my money I would go with the Goldring 1012 or 1042 and they would suit the Rega very well.
__________________
Rega RP6 - Goldring 1042
Rotel RCD 965BX
Sony TA-F700 ES
Naim NAC A5 - Neat Petite
AKG K450 - AKG K551
NeoVibe
NeoVibe's picture
Thank you for your comments Mitch.
P5 is in the mail with no cartridge so... Any more feedback? Thanks!
