Red or
8 replies [Last post]
pwiles1968
pwiles1968's picture
I have been considering upgrading the Cartridge in my Genie Mk3 to the Ortofon Red, is there an anything else I should look at in a similar price range (Under £70).
__________________
Stereo -1st Gen Apple TV with ATVFlash & 1TB HDD > Audiolab CDQ > Bel Canto Evo 2 > B&W 805s
John Duncan
John Duncan's picture
Re: Red or
Does it have an OM5 on it already? If so, there are several OM-series styli that will fit, be of similar-ish quality to the 2M red, and be much easier to fit.
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
pwiles1968
Re: Red or
OMB 3e is on there, I assumed it would be a straight replacement as it was shipped with the Red for the first units but I just missed one of those Sad
__________________
Henley
Henley's picture
Re: Red or
Call me biased but go for the Red, they really are quite superior to the OM models. The benefits gained from the new cartridge far outweight the hassle of fitting it.
pwiles1968
Re: Red or
Henley:
Will the red fit straight on to the Genie3.
__________________
Henley
Henley's picture
Re: Red or
Well you'll have to detatch the cartridge tags, unscrew the old cartridge and fit the new one. but otherwise all you need do is set the tracking weight.
pwiles1968
Re: Red or
Thank you that is what I was expecting.
__________________
noble
noble's picture
Re: Red or
Henley, do you mean that there's no need for alignment, azimuth adjustment etc ?? I'm new to vinyl and I thought all these are necessary should you need to replace a cartridge.
pwiles1968
Re: Red or
I assume alinement's etc would be necessary with any cartridge change and would have done this as a matter of course, think it was more that there would be no major modification for it to fit in place, please correct if I am wrong.
__________________
