Recommendations for inner sleeves
Returning to vinyl after a break of 20+ years, I want to make sure I keep all my new purchases in pristine condition. I've been doing a lot of reading about inner sleeves and am just wondering what the current preferences are ?
The Mobile Fidelity sleeves have been getting a lot of flack for the more recent batches leaving a residue on the vinyl. Sadly the well favoured sleeves at sleevecity.com are prohibitively expensive when you add the shipping from the US.
I think I'd prefer a square sleeve rather than a shaped sleeve such as the Nagaoka No. 102.
Another brand I have seen on a lot of the UK online store are the Goldring / Milty ExStatic Inner Sleeves, but I have read that they are a tad oversized.
Any thoughts and comments welcome.
Cheers,
Nige
I've been using the Nagaoka sleeves for 20+ years and have never had a problem with them. They do the job and are reasonable priced.
Alears,
It was one of the many forums I am now frequenting where someone mentioned when you put the Goldring sleeve into the record cover a bit of it sticks out ? If you have no such protuberance issues then that is good enough for me
Nige
Thanks, Paul.
The Nagaoka are reasonable so perhaps I will get some of those and some Goldrings and see what I prefer.
Nige
Nige, I haven't bought any for years, but if the Nagaoka ones are 'record shaped' at the bottom, rather than square, then I used to find them harder to insert into the outer sleeve.
The MF ones were always the biz, but if there are issues then I'd go with sampling a few.
I used to get a lot of poly lined paper sleeves from the record companies 'back in the day' before CD, because many liners were paper only. I see they are still on sale, e.g on Amazon at £3.99 for 20, much cheaper than the branded stuff.
I use the ones from Covers33 - very reasonable.
Thanks for all the comments. I think I'm going to give the Goldring sleeves a go for my first batch.
Nige
Hate is a strong word. It's a record sleeve!!
Don't go there, it's not worth it...
Nagaoka's for me, the shape's never bothered me.
+1 for Nagaoka sleeves:)
Hi
Like you vinyl is back into my live after 25 year, who thought that would be possible...
I use the MOFY inner sleeves and love them, my Rega dealer represents them in Portugal so it's easy to me to buy them, bought this week a pack of 50 for 20 euros, each piece at 0,40 cents.
I'm cleaning myself all my vinyl record, just came across in a Potuguese forum with a cheap and simple solution to wash the records, I might just open a thread to share my findings.
I've tryed so many solutions and this one rocks all the other ones out of the ring!
Best REGArds
Really? I did 7 or 8 new ones last night (found a charity shop that had clearly taken in someone's discarded Blue Note collection, 50p each, immaculate!), no issues at all, might I recommend a good hand cream, put a bit of moisture back into your skin? I don't need it personally, greasy enough as it is...
Grab the handles, pull them away from each other, you'll see a couple of pointy bits stick up just inside of the handles, open from there, easy!
They can do, if the original inner sleeve is creased especially but I've always found completely square ones fold at the corners anyway if you try to put them back into an original sleeve, so I think it's as broad as it's long.
Please do, I'd be interested to see that.
I've just bought some Goldring inner sleeves and they are just fine. Not sure where the 'tad oversized' came from.
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Groove Anniversary/Tom Evans Vibe Preamp/Linear A power amp/Acoustic Zen Adagios/ Chord cables
