Recommend me a Cartridge
36 replies [Last post]
d3moliti0n
d3moliti0n's picture
Hi
My current turntable setup consists of:
Dual 505-1 turntable
Rotel RA-820AX amplifier
Mordaunt-Short MS-10 speakers
I would like a new cartridge that will play all types of music very
well from Heavy Metal and Rock to Blues and Jazz and maybe some
Classical (if that matters when choosing, I'm pretty new to turntables
so don't know too much about them at the moment). I have a budget of
about £100'ish but I want to keep it below that if possible. Can you
recommend anything?
Thanks for your help.
jetjohnson
jetjohnson's picture
Re: Recommend me a Cartridge
I reckon I have a pretty "catholic" taste in music much like yourself so I'd recommend a Goldring 2200 (About £100) I just bought one a few weeks ago and am very happy with it. Also you can always upgrade this cartridge later with a new stylus rather than needing a whole new assembly.
__________________
Oracle Delphi 1 / Zeta /Goldring 2200. Onkyo Tr 875. Marantz CD 85 SE.Sony CDX 355 300 Disc CD Multi-Player
Lake Audio 1015 Ft Speakers and Lake Audio Ctr. Wharfdale Diamond III Rears. Ruark Vita 100 Sub Woofer. Pioneer PX 50d Plasma. Denon 1940 DVD. Panasonic DMR ex 777 HD/DVD-R.  Pioneer 989 avi DVD Player.  Sony BDP185 Blu Ray player, Sky HD Box
d3moliti0n
Hi
Is it worth spending a lot on a cartridge when my setup is pretty average overall? I mean, I'm looking at getting an Ortofon OM5E instead now as they are only about £38 and they seem to get good reviews and are seen as reliable.
Dougal1331
Dougal1331's picture
Ortofon 2M Red, about £60...
__________________
Arcam CD72, Rotel RA02/RB03 biamp, TDL Studio 0.5 (or Wharfedale Coleridge- currently undergoing surgery...), QED Revelation s/c, Qunex 4S ics.
PC- Optical to Audio Alchemy DDEv1/Rotel RA935BX/Mission 780/VanDamme Studio Blue 6mm
Greenwich_Man
Greenwich_Man's picture
d3moliti0n:
I had one of those on my setup - was very happy with it - then when I wanted to upgrade I only needed to change the stylus - and have gone up now to the OM10
the record spot
the record spot's picture
Audio Technica AT110E - roughly £35. Legendary cartridge, performance way above its' price band.
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
fatboyslimfast
fatboyslimfast's picture
the record spot:
Was Legendary. Sadly no more.
The AT-110E was discontinued in early 2009...the AT-95E is now the audiophile entry AT cartridge, at around £30-35.
TBH, the Ortofon OM5E is such a good match for the Dual's ultra low mass arm, I can't see a good reason for looking at anything else. And it can be upgraded via different styli, from the 10 at around £50, up to the 40 at £200.
__________________
Sources: Technics SL1210Mk2 with Denon DL110/AT-95E, Mac Mini, Virgin V+.
Amplification: Cyrus 2.
Speakers: Mordaunt Short MS20i Pearls with Fisual Super Pearl 2.5mm cable.
Other kit: More than I should have. My loft is creaking.
Henley
Henley's picture
Bit of a problem there. The Dual CS505-1 was originally fitted with an Ortofon TKS49S cartridge (badged Dual) which used a unique slider mechanism to secure it to the headshell rather than the normal 1/2 inch mounting. Now, at that time there was an adaptor available which meant you could also use normal cartridges but (unfortunately) I haven't seen one of these for over 15 years and there is no other way of fitting a standard cartridge to the deck. If you can find one of these sliders on Ebay then you may be in luck, otherwise you are somewhat stuck with the original cartridge.
Unfortunately, as it was an OEM product, the license for resale was with Dual and (to the best of my knowledge) this has never been released.
Dougal1331
Ah. New tonearm time then...
__________________
fatboyslimfast
TBH, new turntable time.
Dual 505/2s go for about £30 on ebay, and have the standard 1/2" cartridge mount.
The Pioneer PL-12d is also a good bet for similar money (I have both, and for my money the Pioneer is ahead by a fair margin).
Either a 505/2 or a Pl-12d (with either the AT-95E for the pioneer or a OM5E for the 505/2) shouldn't set you back much more than £60 or so. Still well within budget...
__________________
d3moliti0n
Well considering I only bought the turntable, amp and speakers about a month ago (I'm brand new to the world of vinyl and turntables) there is no way I will be buying another of any of those items at any time soon. I just want a cartridge to play records, not some Nasa space station setup. People go into way too much detail for my liking, I just want to collect vinyl and be able to play it at a good quality, I don't want ridiculously expensive components or certain audio qualities etc. Just a good quality playback of vinyl.
I have been told on many occasions that the OM5e will fit a Dual CS 505-1. I have also been told that it is a good cartridge for the money and may be a bit 'light' or 'fatiguing' but I honestly have no idea what that means and I couldn't care less. I just want to be able to play my records without them getting damaged and to a good audio quality. End of.
one off
one off's picture
its a good cartridge so you can buy with confidence
also its upgradeable if one day the urge strikes
d3moliti0n
one off:
Thank you, a straight and to the point answer. That is more like it. I don't really want to know the ins and outs of how these things work, I just want to know whether it's good/worth the money and if it will work with my setup.
Thanks again.
fatboyslimfast
I'm a little offended by your comments - we are only trying to help.
To put things basically - if the headshell (that's the bit on the end of the arm that holds the cartridge) has two screws, you can put on whatever cartridge you want.
If it has only one (as Henley suspects) then you are stuck, and no amount of comments will help.
End of rant.
__________________
d3moliti0n
I apologise if it was a bit strong but as I said, people tend to veer completely off the topic by suggesting I buy new turntables and tonearms etc. Surely there must be simpler ways, such as cartridges available for that specific type of headshell, rather than having to buy a whole new turntable or tonearm, thats if it won't fit, I'm not sure cos I'm not at home at the moment so I can't check the headshell for the number of screws it has.
gregory
gregory's picture
You can buy a replacement stylus from Musonic, good deck, good cartridge, about £25.00.
