20 posts / 0 new
Last post
plastic penguin's picture
Last seen: 1 day 17 hours ago
Question to all vinyl heads.
Does anyone know why a 7" single sounds different to a 12" single or LP? Noticed, have done for years, but never really felt the need to ask.
I've got quite a few 7" singles that I've kept either on 12" single or purchased the LP. The 12-inchers seem to sound more cohesive, generally.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
Hi-FiOutlaw's picture
Last seen: 2 weeks 8 hours ago
RE: Question to all vinyl heads.
They do...???
Never notice... I've only 8/9 singles but, will do a test tomorow. :?
Rega RP6/Goldring Elite MC>Clearaudio Basic Plus
Synology NAS>Auralic Vega>Pathos Classic One MKIII>Dynaudio X12
jcarruthers's picture
Last seen: 2 years 10 months ago
Presume it's because all the music is on the inside of the disc so tightly packed.
:grin:
Al ears's picture
Last seen: 1 day 12 hours ago
I think it has to do with 'groove spread'. The amount of space you have got to cut the amount of music into the disc.
In digital terms think of it as the amount you have to compress a song by to get it to fit into a given file size. Smile
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
chebby's picture
Last seen: 10 hours 34 min ago
You know how the last track on any LP side usually sounds the worst?
Look at the area of the LP it occupies compared to the area of the first track.
It's a lot less, even when the tracks are of the same duration.
Measure how much length of groove passes under the stylus, in one rotation of an outer track, compared to the length of groove passing under the stylus in one rotation of an inner track.   It's massively longer (but occupies the same amount of time).
Same with a 7" single compared to a 12" single. The musical information can occupy a much larger area (and a much longer groove) on the 12" version.
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
drummerman's picture
Last seen: 18 hours 31 min ago
Yes, regardless of what your parents tried to tell you ... size matters
regards
MajorFubar's picture
Last seen: 1 day 11 hours ago
It's the same reason why singles probably should have stayed at 10" and 78rpm, even after the move to vinyl. But convenience won over SQ. Wow that doesn't happen very often does it [/irony]
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or RS-180
TrevC's picture
Last seen: 1 week 2 days ago
78 is probably OTT.
AmigaNut's picture
Last seen: 2 years 2 months ago
Back in the day, I decided to buy 12 inch only as yes they were better quality.
They also had picture covers simillar to LPs, I assumed the SQ was due to 12 inch being thicker vinyl and the 7 inch were basically cheap & chearful pressings.
I get your points above abiut compression etc and think I agree.
Have to admi I had a cut out picture disc of Macca and Rupert bear to my shame.
AmigaNut
Groovy.
Groovy.
Literally.
I also read somewhere that they often used a higher percentage of recycled vinyl in the mixture for singles than for any other size. The number of times vinyl is recycable is not infinite as it breaks down so just that could be a reason for lesser sound quality as well as less longevity with regards to wear.
regards
Couldn't agree more, DM. This what happens when the eco warriors work in the music industry. Smile
chebby's picture
Or when the OAPEC nations quadrupled the price of oil in response to the USA supplying arms to Israel during the 'Yom Kippur war'.
Or Ronnie McGreasie subsidising the Emerald Isle with arms....
Could go on...
chebby's picture
Could go on...
How did that affect the price of oil?
Pages
Log in to post comments
