Project Debut Replacement lid
Where do I buy these from? My current one is covered by some brown tape which I applied when I was moving and cant the stuff off now. Thanks
Hi There
I found a supplier now, didnt think they would be so expensive though.
Spare parts just are. Think yourself lucky your turntable isn't made by VOlkswagen.
However, have you tried lighter fluid on the tape?
I didnt think of Lighter fluid. I have already gone down the road of giving the Lid a warm bath to loosen off the tape hopefully & some how clean the gum of. (Get yourself a Seat or Skoda there cheaper to run)
dx052:I didnt think of Lighter fluid. I have already gone down the road of giving the Lid a warm bath to loosen off the tape hopefully & some how clean the gum of. (Get yourself a Seat or Skoda there cheaper to run)
But use the same bosch parts. I have become adept at finding refurbed parts off the 'bay...
Anyhoo, try the lighter fluid, is very good at getting adhesives off.
Okay I,ll try that. I,ll take the lid out of the bath and dry it off then : ) I will also have a look at Ebay whilst I am at it.
Done sorted. Cheers
dx052:Hi There
The lid should cost around £20.00.. With respect, I'd hardly call it expensive.
Hi, The one I found although I didn,t look to far was £45 which I thought was a tad expensive for a dust cover thats all. For future reference were can I can I get it for £20.00. Thanks
dx052:Hi, The one I found although I didn,t look to far was £45 which I thought was a tad expensive for a dust cover thats all. For future reference were can I can I get it for £20.00. Thanks
Considering I paid £40 for a debut on fleabay, yes £45 is ridiculous...
Our website or any of our dealers
margetti:Considering I paid £40 for a debut on fleabay, yes £45 is ridiculous...
Think of those 'poor' Linn Sondek owners wanting a lid. (£139)
chebby:
Now THAT really is ridiculous! I mean, really, how can that price possibly be justified for a piece of plastic... the economic laws of supply and demand have a lot to answer for sometimes...
Thank you for sharing this valuable information. Right now I'm busy with my project and then I'm planning to go to Canada . That's why these days I'm too busy with my documents and can not afford to search for these same things. Keep sharing.
if you contact the uk distributor theyll either supply with you one or tell you where to get them
your local project dealer should be able to help as well
