Pro-Ject Debut II Counterweight Help
Tue, Feb 12 2013, 9:44PM
Hi all,
I'm a beginner to the world of vinyl, although I am fairly knowledgeable with music, guitars, and tech
However, I'm really struggling to set it up correctly, and cannot seem to find ANY videos online showing me how to do it. The Debut II doesn't have any of the dials (or at least the one I have has no dials) and is just the weight block with a small weight balancing on a hook. How do I do this correctly?
Is there anything else I might need to do/know before I start playing?
For reference, the Debut II is going into the ProJect phono box MM into Prodipe Pod3 monitors (I'm a student so I can't really afford much newer gear!)
