4 posts / 0 new
Last post
Mike_Schmidt's picture
Last seen: 10 months 4 weeks ago
phono stage upgrade
Would moving to a Leema elements phono stage be a upgrade from my Moon LP3? I wont be able to hear the Leema only it. I find my Moon dry and involving.
floyd droid's picture
Last seen: 2 years 6 months ago
Re: phono stage upgrade
Mike. are you still running the dynavector ?. If so i think you should seriously consider a dino+. Its got boogie factor if thats what you are after plus enough adjustable gain to sink a battleship, therefore you wont be winding your vol control all the way around to the stop when you want to get party levels out of your TT. The Dino runs fine through Parasounds, been there done that. Just a thought mate. Big Smile.
Well thanks boss good reply that has always been a consideration and I have issues with volume loss now having to hit midnight and even at that sometimes is questionable. I have never heard a bad thing about dino+. Thanks
No problem mate. If you go for it and for some ( i doubt ) reason ,you dont get on with it. It will sell on easy peasy.
Log in to post comments
