14 posts / 0 new
Last post
james67's picture
Last seen: 7 months 2 weeks ago
Ortofon 2m Red Cartridge Damage.
I'm wondering are these easy to damage.
I replaced mine with the one that came with the project debut 3 as it had , had a bit of hammer one drunken night with a few mates.
I put it back last night one channel was ok the other no sound apart from a prominent buzzing.
I checked the cables were ok , tried another amp , tried different phono leads and still the same , even clipped on an old spare 2m on , same result.
Put the pre - fitted cartridge back today and that seems to work ok , so have damaged the 2m red cartridge?
james67's picture
RE: Ortofon 2m Red Cartridge Damage.
Anyone , any opinions?
Lost Angeles's picture
Last seen: 5 days 15 hours ago
First rule of vinyl- avoid when drunk.
Not sure how you could damage the cartridge, the stylus yes. Your post reads that you have replaced the stylus and you still have the same problem - is that correct.
<p>Michell Orbe SE. Origin Live Illustrious 2/3. Transfiguration Axia S. Roksan amps. Dali Epicon 2 speakers.</p>
james67's picture
The problem only occurs with the 2m cartridge , but the original pre fitted cartridge (different type of ortonfon) is ok.
So you have damaged the stylus(needle) not the cartridge. You can get a replacement stylus for this cartridge. Are all 4 connectors on the rear of the cartridge sound.
To damage a cartridge I think you would need to give it a hefty whack with something.
james67's picture
Am not as i have two 2ms one cartridge and both have the same issue so it may be the cartridge itself ,good advice about drink & vinyl!
james67's picture
So have you got 2 off 2M cartridges or 1 2M Cartridge and 2 stylii.
james67's picture
2   2m stylus and 1 cartridge , just assuming the cartridge may be an issue.
Henley's picture
Last seen: 1 year 6 months ago
They're not easy to damage but it sounds like a coil or internal wire may be broken on the cartridge.
UK distributors for Pro-Ject, Ortofon, Roksan, Unison Research, Lehmann and Reloop
Here to help.
james67's picture
Thanks for the reply , was a bit unsure as regards buying a whole new cartridge , might be an option when i have the money.
Would that issue explain the speaker/distortion problem that i mentioned?
Henley's picture
Yes it would.  If internal wires are broken or touching, it would have the same effect as touching the phono cables.
Here to help.
james67's picture
Thanks for clearing that up , don't have the money to sort anything atm , but has put my mind at rest knowing its not a record deck issue etc!
james67's picture
Bought a new cartridge on Saturday and its ok , Fitting them is fiddly , but i find the set up etc is more of a pain in that is everything correct etc!
But thanks for the advice to those who have replied to my query.
Log in to post comments
