Depends on your downforce. I forget which one you have, but from the RPM5 manual (which prob has same tonearm), 1-1.4g goes in the slot nearest the counterweight, 1.5-1.9 goes to the middles one, 2g and above goes to the farthest one.
Course, it's so fiddly that you'll be lucky to *choose* which slot it goes in...
__________________
CA StreamMagic 6 (pre-prod) | CA 751BD | CA 651A | PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
