1 post / 0 new
millerman's picture
Last seen: 3 years 1 month ago
one channel down
Hi all
Ive got one channel that has started to crackle and sometimes completly gives up leaving a quietish distortion.
Ive ruled out the pre and power amp.  Ive changed the interconnects between the phono stage and the pre amp.  So, its either the turntable or the Phono.
Im guessing the signal to the phono is at fault, is there anything I can do to check the turntable.  At the moment its playing fine and usually starts to occur after about 10  mins of play time.
The turntable is an  inspire Eclipse SE2, the cartidge is a ortofon rondo red, the phono stage is  Whest two.
kind regards
