Okki Nokki – Am I expecting too much?
21 replies [Last post]
progwardy
progwardy's picture
I suspect I've answered my own question in the positive!
I’m currently using a newly serviced and updated Linn LP12 with a moving coil Dynavector Karat 17D3.
I’ve had my Okki Nokki RCM for three weeks. I’ve used L’Art du Son cleaning fluid, triple distilled water and all housed in amber glass bottles. I’ve varied the amounts used, the ‘action’ used to spread the fluid on the record (the ‘scrubbers’ and ‘spreaders’ debate). I’ve varied the amount of time I’ve left the fluid on the LP before vacuuming. I’ve used a ‘Milty Zero Antistat’ before the process. I’ve also tried using it after the process as well in case I’ve generated any static during the process. In every other way I’ve followed the instructions to the letter. I’ve also got two LPs on which I have tried several cleans. There seems little improvement between cleans two and three.
The symptoms are the snap, crackle and pop. Without a doubt on some records there has been an improvement. On others it seems negligible. Only on two LPs have I managed to get a near to silence finish (out of 15).
My initial observations are that the waste fluid is a very murky colour which would indicate the machine is cleaning. The supplied brush seems hopelessly inadequate for the task. It’s started to shed hairs and I do wonder how much of the bristle is actually getting into the groove. Some other threads/forums seem to suggest a velvet strip would be more appropriate. There are several very expensive brushes that might fit this bill.
I do understand that a badly damaged LP is irretrievable. However the LPs I’ve been cleaning do not look badly damaged and the RCM does make them look like new. Unfortunately it’s in the sonic department that it seems somehow lacking.
My specific questions are:
1.       Am I using the best fluid? The web is awash with suggestions. Any recommendations based on use would be welcome.
2.       Should I be a ‘spreader’ or a ‘scrubber’.......?
3.       The brush needs replacing. I’m thinking of a homemade version using adhesive velvet strips if my local shop can supply it. Any recommended alternatives?
4.       Am I using the most effective anti-static solution? There are several ‘wipe on’ products that get varying comments on the web. Again, any suggestions welcome.
5.       Do I just need to keep repeating the process? (Am I being too impatient?!)
6.    Any basic techniques I've missed on trawling the web that you could recommend?
My continuing vinyl journey has been an eventful, and largely positive one. I can hear with some LPs what is achievable. It would just be great if my substantial investment could be producing slightly more successful results. I also supect I need to be more careful in the vinyl I am choosing to buy - it's nearly all second hand - but even the clean looking stuff is having very mixed results. Thanks in advance for any suggestions you may have.
Kevin.
kusum65
kusum65's picture
Re: Okki Nokki - Am I expecting too much?
I got back to vinyl a year ago and have a okki nokki. I cant get rid of pops entirely but it cuts out the static pops. I find some of the new vinyl can sometimes crackle and pop a lot. I wonder sometimes if its the rough cheap sleeves they use.
As you may know some stylus are more prone to surface noise, my ortofon picks up noise more than my Nagaoka.
I too have had variable results with buying. Some stuff , 2nd hand or new reissues , can sound so good as to better the cd easily but others can sound worse. In terms of new stuff, i find Rhino reissues always seem to sound superb imo. With 2nd hand stuff it comes down to wear and whether you have a good press or not.
Not a consistent format but when it comes right i still think it gives me more music pleasure than digital.
kernow10
kernow10's picture
I dont pretend to be an expert on this but the symptons you mention seem inherent in some vinyl.
The snap, crackle and pop just seem to be there, at least on some records. I have been buying records for decades now and some of the worst offenders have been LP"s that were bought new. Some of my more recent purchases have had more of a problem than stuff I bought in the 1950/ 1960"s. Compared to earlier purchases I notice that later LP"s are made of much thinner, lighter vinyl. Whether this is a factor I am not sure.
respe
respe's picture
I use a Okki, and although it will not (nothing can) remove all the snap and crackle from LP's, it does remove a lot. When cleaned, you are putting them into new inner sleeves I hope. Also the static could be worse this time of year if the room has a dry atmosphere from central heating etc.
progwardy
progwardy's picture
Yep - new poly-lined inner sleeves. Another day of mixed results. I do think that perhaps I need to be a little more select about the second hand stuff I buy. Although a visual inspection in the shop doesn't always reveal the horrors that wait!
Problem is when it works - it works very well and I then want all my vinyl to sound as good! Have ordered all manner of new brushes etc with which to play........
Thanks folks for responses!
kiddabc
kiddabc's picture
RE: Okki Nokki – Am I expecting too much?
where do you get triple distilled water?  I have tried everywhere I can think of, no one knows what I am talking about.
CJSF
CJSF's picture
Why triple destilled water?  The home brew recipies I have see always seem to say 'distiled water' that says 'vintage Halfords'  to me?
CJSF
The_Lhc
The_Lhc's picture
Online
RE: Re: Okki Nokki - Am I expecting too much?
I've got an original Disco-Antistat and I must admit I've been mildly disappointed with the last few cleanings and those were done with brand new fluid. Can't help thinking it's not rinsing the dirty fluid away, so when they're left to dry the rubbish just dries back on the record. Got nothing to prove that's the case, it's just an idea that's wedged itself in my head now.
__________________
No signature worth mentioning...
CJSF
CJSF's picture
Mmm . . . I remember seeing on here a while back, someone put the record in an electric drill to centrefuge the liquid off (after removal from the trough:rofl: ). Looking at the spindle, seems perfectly feasable idea, provide the drill has a reduced or veriable speed control triger. In fact a simple gig made from MDF to rest  the drill in so that the other side of the spindle is also suported seems a good idea.
CJSF
The_Lhc
The_Lhc's picture
Online
Sounds a bit messy CJ!
Anyway it's almost certainly my imagination, I've only played about three records after my last cleaning session, the first one, an old copy of Ian Dury's New Boots and Panties!! sounded horrible on the first track, so I took it off, examined it under a bright light (we only use a couple of dim lamps in the evening) and I can only imagine someone's been attempting to scratch with it, the first track has visible damage, the bottom of the grooves actually looked white, I've never seen anything like it. The rest of that side looked ok but I couldn't be bothered to try it. I then played a couple of Shakatak LPs which sounded very poppy and noisy, so I looked at them under the light and realised I hadn't cleaned them at all, they were filthy (visible patches of surface dirt)! I haven't cleaned them yet, they'll be a proper test.
__________________
CJSF
CJSF's picture
Or . . . how about wraping a 'lint free cloth' around the small head of a vacume cleaner, the new super Dyson handheld maybe, drill a spindle size hole in a 60-70mm block of wood.  Clamp the block in the vice, drop center hub spindle in hole, carfuly rotate record and very lightly vacume water off?
Very 'heath robinson' . . . but that my middle name . . . puzzled   Not sur how the small quantity of water would affect a mains cleaner, use a wet and dry of a battery job?
CJSF
The_Lhc
The_Lhc's picture
Online
I think I'll let you give it a try and get back to us!  Smile My missus will brain me if I destroy her Dyson!
__________________
CJSF
CJSF's picture
Wink
Mmm . . . I think the manual trough type cleaning systems are messey anyway, my answer is, do it in the shed, one will not be doing more than say half a dozen - to a dozen in one hit.  My thinking, in cold weather the solution wont evaporate quick enough, its a messy job in the house any way, up the shed I can spin to my hearts content.  Bring the rack of clean records down to the house, stand on the kitchen table for a while which has a radiatior close by.
I have also read on the web, the solution supplied with Disco-Antistat, did not evaporate properly, leaving a 'white residue'?  As I say thats what I have read, it was prodably 6 or 9 months ago.  I will mix my own 3 to 1 + a drop of Fairy or rins aid, need to pop out for a bottle of 'vintage Halfords';)
CJSF
CJSF
CJSF's picture
I use an old wet and dry in the shed anyway . . . done carfully, I think the centrifuge idea is a good'un . . . problem is, some people live in flats, no shed to escape tobanging head against wall
CJSF
ifor
ifor's picture
I've never used an RCM, but I eliminated a huge amount of pops and crackles by switching from a felt mat to an Achrimat from Inspire Hi Fi.
__________________
Source 1) "Inspired" Manticore Mantra turntable c/w Rega RB 301 arm, Goldring 1042 MM Cartridge, Graham Slee Reflex M phono stage, Graham Slee CuSat 50 interconnect
Source 2) Cyrus CD8 SE CD player
Source 3) iTunes (ALAC), iMac, Devolo Homeplugs, Apple TV3, Toslink, Arcam rDAC
Source 4) Technics SL-7 linear tracking turntable.
Roksan Kandy L3 amp, Spendor A5 speakers.
Other rooms: more Airport Expresses and Homeplugs with Denon AV system and Denon Mini system.
progwardy
progwardy's picture
The various recipes I found kept going on about the purest water you can get! Sure it doesn't make a difference and the only water I could find at the time was from eBay and was...triple distilled!
