New Rega Fono MM
Hi All
Has anyone heard it yet? looks very nice.
Cheers, Ed
Can i post a link from a dealers website?
Yes. So long as you are not the dealer.
Ok try this...scroll down until you get to it.
I would use the phono stage on the Luxman but i cant have my TT close enough to do that. I have to have the phono stage with the turntable. I've not long realised that you can only send a line level signal down a long interconnect otherwise it sounds pretty naff.
I'm using a fono mini at the moment but i like the look of the new Fono.
Cheers, Ed
Ah ok. New casework certainly. (To match the new look TT-PSU)
Not sure how 'new' it is inside though.
I see the designer - Terry Bates - is still leaving messages inside his creations
(I like "Best used with EL84 valves" inside the Rega DAC.)
- Login to post comments
Have you a link?
Rega aren't showing it on their website. (Only the old one.)
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
