31 posts / 0 new
Last post
domenn's picture
Last seen: 2 months 3 weeks ago
New cart wanted
 Something with very good tracking ability with no sibilance and IGD , and with low surface noise , also to match my phono preamp I want to get the most out of it , deserves better than Elysssssssssss 2  . In the  near future I want to buy RP6 so the cart will be used on RP6 as well. I was thinking ortofon 2m blue or Rega Exact that would be on the top of my budget .
Thank You fellas
Naim Uniti2, Rega RS5, Leema elements phono preamp., Rega P3-24, Nagaoka  MP-110
plastic penguin's picture
Last seen: 3 days 12 hours ago
RE: New cart wanted
Thank You fellas
This'll be the hi-fi equivilent to viagra, certainly give your music pleasure a substantial lift.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
chebby's picture
Last seen: 5 hours 41 min ago
RE: New cart wanted
Goldring 1042.
I used one for almost 11 years in a Rega Planar 3 (with two replacements of the stylus).
Superb. (In my opinion.)
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
stevebrock's picture
Last seen: 2 days 5 hours ago
RE: New cart wanted
Nagaoka MP-150 or MP-200 would be my choice!
The Nags are a lot more relaxed than the Dyn 10x5 - obviously the Elicit's phono is nicely matched with the Nagaokas!
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
domenn's picture
RE: New cart wanted
In Birmingham is available only Goldring from those You've mentioned in Audioaffair but about £50 more than online . And there is no way I can fit that cart on my own I am only starting with vinyl . There is Music matters shop Superfi (they dont do cart fittings) and Richer S.  So I have limited choice
RE: New cart wanted
IMO the Nagaoka MP-110 wipes the floor with the Elys 2, and yes I have owned both carts on Rega Decks
The MP-110 can be found on ebay for £89 delivered - bargain IMO
domenn's picture
RE: New cart wanted
Sadly I don't know anyone who would fit it for me , Steve how did You find Exact against Elys2 ? In term of tracking difficult passages and overall presentation ? Is it worth that money ?
Al ears's picture
Last seen: 3 days 8 hours ago
RE: New cart wanted
Agree with chebby on the Goldring and again with the Nagaoka MP-150 it all depends on which suits your budget. I'd edge towards the Goldring.
If you cannot fit it yourself it would be worth finding a dealer in Birmingham and pay them to fit it to your arm rather than just going with what is available locally.
Come away from the Rega's in my opinion.
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
RE: New cart wanted
Personally If i had the budget for an Exact, i would get something better. The Exact isnt a bad cart and is tuned to Regas phono stages but you can get better like the Goldring or Nagaoka.
I too was nervous - but fitting a cart is quite simple, plenty of folks on here can guide you through it!
PS i never had a problem with the Elys2 or Exact mistracking or inner groove distortion, they are similar carts IMO with the Exact having a bit more bass and refinement
domenn's picture
RE: New cart wanted
[/quote]
so before I spend money on new cart I am going to buy HiFi News Test LP and I'll see if my settins are ok and It will get rid of my vinyl HiFi paranoia  Smile
is the Analog studio mirrored cartridge aligment protractor correct tool for Rega tables and for all cartridges ?
BigH's picture
Last seen: 1 day 1 hour ago
RE: New cart wanted
You could try Fiveways Hi Fi in Birmingham apparently he is really good with turntables.
Listen to the music, not the hifi.
domenn's picture
RE: New cart wanted
thanks for tip , just have sent him email
and he stocks Avi adm 9 so I'll hear what is all that fuss about   Smile
RE: New cart wanted
oh dear
you got a great amp & speakers there fella
domenn's picture
RE: New cart wanted
so He charges £40-50  for fitting cart and setting   :O
I expected 10-15
domenn's picture
RE: New cart wanted
Stevebrock what aligment do You use ? I've set  VTF 1,75 using my digital scale but on the tonearm dial it shows something over 2 , how can it be so inaccurate ? It means that people with no scale setting VTF on dial they using wrong tracking force , may be 1,5 or less?
RE: New cart wanted
I use the Rega aligment protractor!
The VTF tracking dial on Rega arms is only really a guide!
I set everything to 0, both VTF Dial and Bias
Then I balance the arm to so its hovering over the platter by 1mm by adjusting the counter weight
I then dial in desired tracking weight
Then have a quick check on the scales what the Actual tracking force is then adjust VTF to get the desired force as indicated on the scale
I experiment with the bias
£40-50 is a joke - its a 15 min job! Fit the cart self as long as you take your time, have all tools to hand and use a stylus guard.
Pages
Log in to post comments
