7 posts / 0 new
Last post
AtBs's picture
Last seen: 3 years 10 months ago
Need some turntable advice
stevebrock's picture
Last seen: 11 hours 43 min ago
RE: Need some turntable advice
post again fella - you will get used to this site doing that!
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
AtBs's picture
Thanks for the encouragement Steve! So, here it is a more detailed description of my actual system:
- amplifier       ROTEL ra 1520,
-power amp   ROTEL rb 1552,
-speakers       B&W CM8.
 As I said,I´m thinking to purchase a turntable to use it as an analog signal source for the mentioned system. Actually,could be any other device which offers a clear and natural sound.Allocated budget 400€-600€.
 Any suggestion?
AtBs's picture
 Hello again! Also I have an iMac ,2010 model. Can it be used as a CD player or media player for flac files.I don´t know if the sound chip(card) is good enough to obtain a quality sound.
Is there anyone who have knowledge in this area?
Thanks!
ifor's picture
Last seen: 1 week 4 days ago
You can use the iMac to play ALAC files from iTunes, or FLAC files with a third party iTunes plugin.  Ideally you would want an external DAC but the iMac isn't too bad without.
"Inspired" Manticore Mantra TT, Technics SL-7 TT, Slee Reflex M phono preamp.  Cyrus CD Xt Sig.  iMac, Raspberry Pi c/w HiFiBerry Digi c/w Volumio or Rune Audio, Arcam rDAC.  Roksan Kandy LIII amp, Spendor A5 speakers.
jerry klinger's picture
Last seen: 6 months 13 hours ago
AtBs wrote:
I´m thinking to purchase a turntable to use it as an analog signal source for the mentioned system. Allocated budget 400€-600€.
 Any suggestion?
Rega RP3/Elys
secondhand Thorens TD166 etc from ebay
ifor's picture
http://www.inspirehifi.co.uk/apollo.html
Maybe just out of budget.
http://www.inspirehifi.co.uk/assets/pricelistmarch13web.pdf
Log in to post comments
