3 posts / 0 new
Last post
jcarruthers's picture
Last seen: 2 years 10 months ago
Michell Engineering Rega 3-Point VTA adjuster
I bought one of these as I wanted a way to adjust VTA more precisely.
It's beautifully made — really really beautifully made. It keeps everything perfectly rigid too — it works with a large screw thread.
I bought mine in anodised black — looks like it's OEM — except of course Rega don't do VTA Smile
One issue caused by the Technoweight is that you can't get to the rear screw without removing it.
Am tempted to drill out the self tapped holes and replace with proper bolts — that way they can be loosened from below whilst being held above with an allen key — also I might trust them a bit more.
http://www.michell-engineering.co.uk/tonearms/new-rega-3-point-vta-adjuster/
stevebrock's picture
Last seen: 5 days 8 hours ago
RE: Michell Engineering Rega 3-Point VTA adjuster
mmmmm think I may have to get one of these now!
have you been playing with the height? or have you just got everyting level (arm)
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
Nope — I am off to Johannesburg on business for three weeks tomorrow so decided that listening to vinyl before I go was the priority.
Also, I've lost the bubble level.
Log in to post comments
