27 posts / 0 new
Last post
Yamyam's picture
Last seen: 1 year 2 months ago
LP12 Revival - Advice please
Hi, I have a dusty LP12 in storage, from what I remember with Basik arm and K5(?) cartridge.
Feeling all nostalgic, I'm considering "dusting her off", but do remember that when walking across the floor, the arm would bounce all over the place (never did get the hang of adjusting it).
So, my questions are:
How much should I budget for a service?
As a minimum the stylus would need replacing (or do I have to replace the cartridge to do this?), but am conflumuxed here....
Would also need a 'phono stage, have been looking at the Rega Fono Mini A2D
Knowing what a spiral this could potentially be, I didn't want to spend a huge amount.....so any sensible advice would be truly appreciated.
LP12 / Sonos Connect / Fiio X5 / Audiolab 8200DQ / 8200P / LS50
Jim-W's picture
Last seen: 1 year 5 months ago
RE: Hi Yamyam. My advice would be
Hi Yamyam. My advice would be to get it serviced by a Linn dealer or at least somebody who has sound knowledge of an LP12. The suspension will probably need tuning and the power supply may need upgrading although you may be lucky. As far as I know, Linn has discontinued the K5 so I would suggest replacing the cartridge although you may pick one up on ebay Perhaps a better idea would be to get the dealer to fit a cartridge;a cheap AT-95e would at least sound ok and enable you to play records. I wouldn't go above about £120 for a cartridge on the Basik arm which get you an Ortofon 2M Blue. As for cost, it depends on what needs doing and how much you spend on the cartridge. £300/£400 maybe.all in. As you state, the upgrade path is ridiculously expensive so be wary of the sales patter:new arms, bearings and a more rigid subchasis are all very tempting. Good luck!
Al ears's picture
Last seen: 15 hours 59 min ago
Sell the LP12 as is and use the money to get a modern 'all in one' turntable pre-set in the factory? Smile
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
altruistic.lemon's picture
Last seen: 2 years 1 month ago
RE: LP12 Revival - Advice please
Best bet is to approach a dealer and find out what your turntable already has in terms of upgrades, plus go for the service.
Nice turntable, but.
drummerman's picture
Last seen: 16 hours 30 min ago
Because of the elevated second hand prices for LP12's, aftermarked modifications are not cheap.
I can't say whether they are worth the expense or not but if you sell your LP12 you should at least get good money for it.
With the proceeds I personally would get a Technics SP10. There have been a couple on the bay lately, selling for around £250 to £400 with the separate power supply( w/o arm, plint etc). Refurbished and ready to use they can cost up to £2k. These are ex-broadcast decks with far superior specification/build than an LP12, even in MKl form (the later ones are even better) Add a good arm/cartridge combination and have a custom plint made. Lovely.
regards
Al ears's picture
regards
I quite agree drummerman. I am thinking of heading down the that direct drive route myself.
Yes they're great.
Even my lowly SL-7 (and 6) are nice, as is the Sony.
I would still want a belt drive in my collection though.
regards
nopiano's picture
Last seen: 2 days 18 hours ago
LP12
Earlier this year I was quoted about £250 for a full service on my old LP12. It was a Valhalla but no mods since. The suggestion above to budget up to £400 including a new cartridge is probably about right.
In the end I was a bit skint earlier in the year and had bought a new Michel TT in 2011. I sold my LP12 to the guys at hififorcash for over £500 (it was mint) as I didn't have the confidence to use eBay for an expensive and delicate item. They sold it on for about double, so everyone won! I'd recommend them if you decide to get something newer or easier.
Krell CD and amp, Michell/Rega/Grado for LPs, Hitachi and Sony tuners, Nakamichi cassette, SBT streamer, Chromecast audio, Sonus faber Concerto Grand Piano spkrs. Qobuz > iPad > AudioPro Allroom Air One
Sensible advice is to service the LP12 and find out whether it has the minimum upgrades such as the Valhalla power supply. You'll have a turntable which sounds ace, is a real classic and will still be working 50 years hence. There's also few turntables that keep their value as well as an LP12 does, it's the Rolex of the analogue world!
Nopiano, not sure everyone did win. You'd have made far more on the Hifiwigwam site.
AlbaBrown's picture
Last seen: 1 month 1 week ago
A basic service would normally by under £200 and is an absolute must in terms of getting the deck to sound how it should.
If there is anything more serious that requires attention (i.e motor/psu faults, or the Basik just being knackered - Linn's quality control back then wasn't super) a good dealer will advise on that before carrying out any standard work.
If alls well replacing/upgrading the K5 is so easy, it was just a reworked cheap Audio Technica anyway, and a good budget cartridge like an Ortofon OM2 Red would easily outperform it.
Would not entertain selling it just to buy another old turntable as you'll just be presenting yourself with the same sort of challenges if it isn't fully refurbished!
And if it end's up going through a little Rega phono stage it'd end up being a waste of time and effort anyway!
Yamyam's picture
Thank you very much
Thank you very much everybody!
I think I'm going to get it serviced and take it from there, I'm not convinced about selling it to then get something else - besides my nostalgia tells me that some of the best music I've ever heard has been through it!
AlbaBrown - your comment worries me, what's wrong the the mini-Rega phono stage? Any other recommendations here? Will be connecting through an Audiolab 8200DQ/8200P.
Paul Clarke's picture
Last seen: 6 months 2 weeks ago
Not sure some of these people would agree!!!!!
http://www.whathifi.com/forum/hi-fi/whats-linns-big-secret
Linn LP12 (Lingo, Ekos & Lyra Delos) - Audio Research SP9 - Bryston 4B  ST - PMC OB1 - Chord cables- Blok Stax 500 rack - Isotek Sirius mains filter.
CJSF's picture
Last seen: 14 hours 57 min ago
Not a Linn fan or expert,
Not a Linn fan or expert, however, as you have one and they were good in there day, worth a service IMHO. The arm dancing about when walking on the floor is the bit that worries me.
The arm needs setting up properly, (by the dealer) a decent budget cartridge and a proper TT support will make the difference here. A wall mount TT support will solve the problem, then sit back and enjoy through your chosen phono stage . . . wait for the vinyl bug to bite deep, then you can decide where and if you want to progress . . . Dirol
CJSF
Al ears's picture
RE: Not a Linn fan or expert,
CJSF wrote:
Not a Linn fan or expert, however, as you have one and they were good in there day, worth a service IMHO. The arm dancing about when walking on the floor is the bit that worries me. The arm needs setting up properly, (by the dealer) a decent budget cartridge and a proper TT support will make the difference here. A wall mount TT support will solve the problem, then sit back and enjoy through your chosen phono stage . . . wait for the vinyl bug to bite deep, then you can decide where and if you want to progress . . . Dirol CJSF
CJSF is right in some respects. The arm dancing is a problem, however, the need for a wall mount support, whilst nice to have, should not be required once the turntable has been serviced.
The suspension / arm balancing really needs looking into by a dealer if you cannot do it yourself. It is possible the cartridge itself is still OK and you could replace the stylus assembly by one designed to fit an Audio Technica AT95E. I think your deck requires a much better cartridge than this though if you decide to keep it. Something along the lines of an Ortofon (as previously recommended) or a Shure M97XE at a minimum.
Have fun! Smile
PS: You will know when the vinyl bug has bitten you because the symptoms are:- instant urge to rush out and make very expensive irrational decisions and the mad desire to purchase thin round black discs with a hole in the middle.
stevebrock's picture
Last seen: 5 days 9 hours ago
Talking to my local hifi dealer in the midlands (LP12 experts) so you probably know who I mean!
I was just talking generally about them and he commented that they are way over priced on fleabay and one costing £7-800 is going to need some serious money spending on it to bring it up to scratch - in his words 'better off getting an RP8"
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
MajorFubar's picture
Last seen: 15 hours 23 min ago
drummerman wrote:
Yes they're great.
Oooo I've got an SL-6 in the loft. Totally forgot about that!
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or Audio Technica ATH-M50X
Pages
Log in to post comments
