Just taken the plunge back into vinyl
7 replies [Last post]
rjb70stoke's picture
After much deliberation having read many posts on here, I decided I was going to give a turntable and vinyl a try.
So, not wanted to spend (waste) too much of the hard earned, I have today picked up a Technics SL-1900 from ebay. Having got it home, it has an Ortofon FF15eMkII stylus, and appears to play perfectly with my old Joshua Tree LP, that was left in a cupboard at my mums.
Has anyone got any advice on setting the turntable up for its optimal performance? and is the stylus any good, or would it be worh investing in a new one?
__________________
AV:- Denon AVR-2113 Receiver, Kef 1005.2 speaker package, Apple TV (3rd Gen), PS3 Slim, Sky HD, Panasonic TX-42UT30 TV.
HiFi:- Denon PMA-355UK, Technics SL-1900 turntable, HTPC, Mission 733i speakers.
mitch65's picture
RE: Just taken the plunge back into vinyl
Congratulations and welcome back from the dark side! Wink
As a matter of course I would change the stylus simply as it could be knackered!, about 14 quid should get you a replacement stylus or take the plunge and change to an Audio Technica at91 for under £20.
__________________
Rotel RCD-965BX
Spotify - Yamaha R-N500 Network Receiver
Denon TU-260LII
NAC A5 - Spendor SA-1
AKG K551
Thanks for the reply. Do you mean replace just the stylus with the AT91, or the cartridge. I can get the cartridge for £20 or the stylus only for £10
__________________
mitch65's picture
You would have to get the whole cartridge, for £20 it's a steal Smile
__________________
Rotel RCD-965BX
Denon TU-260LII
AKG K551
MajorFubar's picture
Wouldn't he be better off just getting a new stylus for the Ortofon FF15eMkII cartridge which is already fitted? It would save a lot of faffing around fitting a new cart. From my memory of the dim and distant past, the FF15 was quite highly regarded, was it not?
__________________
Main system: Mac Mini 2011 • HRT II+ DAC • Lacie 3TB Cloudbox NAS • Marantz CD63KIS • Marantz PM66 KI • EB Acoustics EB2
In storage: Thorens TD160 (no cart) • Cyrus 2 + PSX • Cyrus tuner • Technics SL-P777 • Nakamichi DR-1
Al ears's picture
It was indeed MajorFubar............in it's day. I ran one on my first ever turntable.
However if it has been on his deck since new it is probably well past it's sell by date and things have moved on in the world of cartridges.
I would agree with you though that it is a lot less faff just fitting a new stylus, however, he will have to change the cartridge one day, best to start now.
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 dac/Tom Evans Groove Anniversary phono amp/Tom Evans Vibe preamp/Linear A power amp/Acoustic Zen Adagios/Chord cables/Oppo 105EU.
Why would you want to put a cartridge with a conical stylus on the arm? Surely you're better off putting a new elliptical stylus on the Ortofon.
It's a better cartridge anyway. The AT91, unless it's changed a lot, is the base of all base cartridges.
Thanks for the replies. Ive been having a look at styli for the Ortofon Cartridge.
Any ideas which would be best to go for? There seems to be lots of choice of 3rd party products, but very hard to find a genuine Ortofon one. Ive seen a NAD stylus which is suitable for the cartridge, and think I'd rather go with a name I know.
Initially I think I'd rather go for a new stylus until I get to grips with the turntable, setting up a cartridge seems a little beyond my knowledge at the moment.
__________________
