I've just bought a Roksan Radius 5.2
214 replies [Last post]
Just won on ebay for £611, includes 5 year warranty.
Have I done a good thing? <img src=" />
__________________
LOUNGE:  Panasonic TX-P50GT50 (is poorly) / Panasonic DMP-BDT120 / Yamaha RX-A2020 / Dali Zensor 3 (front) / Dali Zensor Vokal (centre) / Mordaunt Short MS20i Pearl Edition (rear) / Q Acoustics1000Si (sub) / Roksan Radius 5.2 / Ortofon Super OM20 Cartridge / Sky HD / WD My Book Live 2TB / Seagate Expansion 2TB / Nintendo Wii / Tacima CS-929
BEDROOM:  Samsung LE32C450 / Sony BDP-S360 / Echostar HDS-600RS / Netgear WNCE2001
stevebrock's picture
RE: I've just bought a Roksan Radius 5.2
I dunno mate!
But Floyd is ya man - he's the resident vinyl guru!
__________________
Icon Audio ST40 III / KT88, Rega Apollo R, DAC, RS3
Rega RP6, Nagaoka MP-200, White Belt, Michell Tecnoweight, Rega Fono MM
Rega Quattro, Couple 1 & 2
I must say though it looks the dogs rubbish
__________________
I'm both excited, and nervous as EDITED.
__________________
nervous as in setting up, nervous/excited
__________________
toyota man's picture
are you spelling b0110cks with an r now?
__________________
As in, will it arrive safely, will the seller be genuine, and will it indeed be the dog's wotsits. :)
__________________
After your previous I sincerely hope so!
__________________
Me too. <img src=" />
__________________
plastic penguin's picture
Should sound the dogs, so you shouldn't have an issue there. Whether the seller is genuine or not is another matter, so fingers crossed on that part.
__________________
Amp: Leema Pulse; Source: Naim CD5i-2, Denon 260MKII, Pro-ject XP I; Speakers: PMC TB2i
Formerly known as plastic penguin
andybeau's picture
Good luck
__________________
Rega Brio R, Inspire Quest Rega TT c/w Clearaudio Concept MM, Rega TTPSU, Marrantz CD6004, MA BX2, MF V-Can II, HRT Streamer2, Acer Aspire 1(Win7 Starter), AKG K451, AKG K550, SoundMAGIC HP100
Yamaha RXV671, Sony BDPS370, Xbox360, Samsung UE37E6300, Wharfedale Diamond 9.1, CM10.1, 8.1 SW150
Well' I had some good luck in the auction, as I won it by bidding just 53p more than the next highest bidder.
I hope I haven't used all my luck up.
Go to go to work now...<img src=" />
__________________
It's a great deck, BBB, but I would say that wouldn't I? (Well, I'm referring to the 5.0 version, not sure what features/spec the extra 0.2 has).
Good luck with taking delivery and set up. The latter, in my case, was fairly straightforward, thankfully.
Interested to hear your thoughts once it's up and running.
__________________
Roksan Caspian Pre amp, Caspian Mono Power amp x 2, NAD M51 DAC, B&W 805 Signature, Roksan Radius turntable, Denon-1713UD, MF phono & headphone amps, PS3, Mac/AE/Apple TV
Al ears's picture
Assuming dealer is a good 'un you should have a good deck there.
I tried to sell my Radius 5 and couldn't get £500 for it.
Is it the acrylic one or the wood effect version?
If it has the same feet as the 5 do not attempt to level the turntable by unscrewing the feet as I found this just left you with a wobbly deck.
Might i also suggest you get something to act a a lid as they tend to be dust magnets!
Pressume it came fitted with the arm, if so just fit cartridge of choice and enjoy ................ it really is a very good deck that is not too difficult to set up.
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 dac/Tom Evans Groove Anniversary phono amp/Tom Evans Vibe preamp/Linear A power amp/Acoustic Zen Adagios/Chord cables/Oppo 105EU.
This is one of the pictures of it from the ebay listing.
Thanks for all the tips Alears.
It has a Nima tonearm, but no cartidge, so I'm hoping the Shure M97xe I bought for the other deck will be good enough, if not, I'll sell it and buy something more appropriate.
__________________
andybeau's picture
Looks very nice
__________________
