5 posts / 0 new
Last post
CJSF's picture
Last seen: 1 week 4 days ago
. . . it won't cast anything . . .
Mmm . . . made a few changes recently, biggest was the inclusion of an 'ISOmat' a 3mm, acrylic platter mat, a brilliant twenty quids worth.
A downer was going deaf, I get realy grumpy . . . :wall: all OK now. So I have spent the past few days catching up, its amazing how much I have missed because of the creeping deafness. Been fitting listening sessions into the snooker schedule on the TV red button.
Also tracking down and purchasing the various small bits needed to produce my DIY vinyl vacuum cleaning machine . . . thats all ready now to start assembly.
I've had occasion to move my TT and isolation board . . . listening yesterday was not good, the detail was there but the soundstage was a mess??? One was agitated last night on the Horlicks hour. Whilst Hazel listened, I thought . . . whats going on, why? The problem was easily solved, but not obvious in detection. The P5 sits on 3 feet, triangle style, the DIY asymmetric, broken bell, isolation board, sits on three adjustable, inverted wood spikes, also home-made. The pattern is the reverse of the TT, ie., two feet at the front of the TT, the board sits one spike at the front, feet and spikes straddle each other.
The single front spike was not in the same position as previous, perhaps a couple of cm's to the right . . . nah, surly not???? . . . that 2cm made all the difference in the world, sound stage back to full width, depth and height. There is even a small improvement in definition in the delicate parts, most noticeable on Miserere, in the distant balcony parts, the individual voices are so well defined.
Another late night listen ensued . . . enjoying some Carol Kidd, Jazz at the Pawnshop, Miserere, Gershwin, one of the beauties of being retired, time has little relevance? . . . unless there is an early Doctors or Hospital appointment, how life changes as one gets older, you have to run your life according to the NHS!
So if you have isolation boards supporting your hifi equipment . . . maybe? . . . a re assessment of the position of the supporting feet might be in order . . . it certainly will not cost anything? I remember when I first did the boards, I tried four metal spikes, three metal spikes mirroring the TT feet, the best was three as a revere image and finally swap the metal spikes for wood/metal hybrid. Critical spike positioning is a new concept for me but logical when thinking about the harmonics in the board?
CJSF
gbhsi1's picture
RE: . . . it won't cast anything . . .
CJSF wrote:
Mmm . . . made a few changes recently, biggest was the inclusion of an 'ISOmat' a 3mm, acrylic platter mat, a brilliant twenty quids worth. A downer was going deaf, I get realy grumpy . . . :wall: all OK now. So I have spent the past few days catching up, its amazing how much I have missed because of the creeping deafness. Been fitting listening sessions into the snooker schedule on the TV red button. Also tracking down and purchasing the various small bits needed to produce my DIY vinyl vacuum cleaning machine . . . thats all ready now to start assembly. I've had occasion to move my TT and isolation board . . . listening yesterday was not good, the detail was there but the soundstage was a mess??? One was agitated last night on the Horlicks hour. Whilst Hazel listened, I thought . . . whats going on, why? The problem was easily solved, but not obvious in detection. The P5 sits on 3 feet, triangle style, the DIY asymmetric, broken bell, isolation board, sits on three adjustable, inverted wood spikes, also home-made. The pattern is the reverse of the TT, ie., two feet at the front of the TT, the board sits one spike at the front, feet and spikes straddle each other. The single front spike was not in the same position as previous, perhaps a couple of cm's to the right . . . nah, surly not???? . . . that 2cm made all the difference in the world, sound stage back to full width, depth and height. There is even a small improvement in definition in the delicate parts, most noticeable on Miserere, in the distant balcony parts, the individual voices are so well defined. Another late night listen ensued . . . enjoying some Carol Kidd, Jazz at the Pawnshop, Miserere, Gershwin, one of the beauties of being retired, time has little relevance? . . . unless there is an early Doctors or Hospital appointment, how life changes as one gets older, you have to run your life according to the NHS! So if you have isolation boards supporting your hifi equipment . . . maybe? . . . a re assessment of the position of the supporting feet might be in order . . . it certainly will not cost anything? I remember when I first did the boards, I tried four metal spikes, three metal spikes mirroring the TT feet, the best was three as a revere image and finally swap the metal spikes for wood/metal hybrid. Critical spike positioning is a new concept for me but logical when thinking about the harmonics in the board? CJSF
I guess being retired means you have a lot of time on your hands Smile
CnoEvil's picture
Last seen: 1 week 1 day ago
.....Ah, I thought you were talking about your dog! :doh:
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
CJSF's picture
[/quote]I guess being retired means you have a lot of time on your hands Smile
[/quote]
 . . . It does when your partner is not well enough to go out for long or far, I need to be about for her.  Hazel is getting better after her majour operation but a trip to Asda is about the best we can manage at present.  Plus the weather, its been £issing with rain for the past couple of weeks, which adds to the problem of Hazels mobility . . . mine too, I dont like getting wet, old joints dont react well to damp either . . . Dirol
CJSF
gbhsi1's picture
[/quote]
CJSF
[/quote] Sorry to hear about your wife's mobility not been great. I know the weather has not been great Smile
Log in to post comments
