Is my belt size too big?
4 replies [Last post]
AndrewAfresh
AndrewAfresh's picture
I’m looking for a belt that will fit my late-1980s Sanyo P 30 turntable; I don't have the old belt so can't measure it, but I calculate the circumference required is 685 plus say 30 for the spindle = 715 mm total circumference. However, no-one seems to sell belts this long – have I calculated something wrong? Thanks for any help you can give.
chebby
chebby's picture
Online
RE: Is my belt size too big?
That's because belts need to stretch a little.  Without any tension they'd just drop off.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
floyd droid
floyd droid's picture
Mantra Audio will sort you out matey. I cant be fagged to post a link, so a quick google is in order. They have your belt in stock according to their webby site.
AndrewAfresh
Thank you floyd droid - I've ordered the biggest belt they have.
floyd droid
Give em a call to make sure that you have ordered the correct one. TB201 (Sanyo all models) 631 mm is the one i reckon you need.
Dunna hurt to check does it  Smile.
