is it possible I have damaged it?
8 replies [Last post]
gbhsi1
gbhsi1's picture
the unthinkinable has happened, I accidentally hit the tonearm whilst the cartridge was in the groove which caused the stylus to skip to a few lines down a record. how can I check if I've caused any permanent damage?
gbhsi1
gbhsi1's picture
RE: is it possible I have damaged it?
by the way it's my rondo red Sad
toyota man
toyota man's picture
possible .in my dim and distant past after a drink or 5 I have done the  same without any damage as tracking at 1.5 / 2.0 grams more likeley to have damaged lp  unless of coarse you put a lot of wait on it but if you only nocked it it will most likely be ok
__________________
gregory
gregory's picture
Check the cantilever with a magnifying glass, it will be obvious if it's damaged, bent either left or right, if it's not it's probably ok, the diamond on the shank are fairly resilliant, tracking vibrations they have to be, if it looks ok play the same record, if it's screwed, it's screwed what have you got to lose, i'd rather replace a scratched record than a cartridge any day.
gbhsi1
gbhsi1's picture
I'll need to buy a magnifying glass. I've played some records and they sound the same and no noticeable difference just my mind is racing thinking I've done some kind of permanent damage.
chebby
chebby's picture
Do you have a digital camera with a 'macro' mode? If so then you have saved yourself the expense of a magnifying glass. (Some digital compacts can focus from as close as a centimetre or two.)
Use the maximum image quality and photograph the stylus. Then crop and magnify the image on your screen. The quality won't be brilliant, but - so long as it's focused on the stylus tip - it will be good enough to see the stylus profile or any damage.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
gbhsi1
gbhsi1's picture
I'll give it a go - thanks chebby!
DougBradyHiFi
DougBradyHiFi's picture
If you place the stylus onto the rotating record and look straight at it from the front the stytlus/cantilever should be in the centre and not to the left or right. Looking sideways on, the bottom of the cartridge should be about 1mm - 2mm above the record surface, depending on the tracking weight applied. If these check out and the sound is o.k. then no harm done.
__________________
Andrew.Davies@ Doug Brady HiFi Warrington, CheshireHiFi and Home Cinema Specialist
gbhsi1
gbhsi1's picture
thanks for the handy tips. if the stylus was damaged wouldn't the sound be different or there would distortion of some kind?
