hum from turntable.
14 replies [Last post]
gbhsi1
gbhsi1's picture
I've moved the dino as far as possible from the turntable but can't get rid of the hum, I use shielded cable and a standard thin wire (shielded too) as the earth connection. how can I eliminate the interference totally? what could be causing it?
Bertie1
Bertie1's picture
RE: hum from turntable.
I had a similar issue especially at volume.
It was like a transfomer hum.
Bought a Tacima mains conditioning 6 way extension and background the noise dropped through the floor.
I know there's bit of a debate about these things but they definitely worked for me.
__________________
Stuff: Panasonic 46gt,110 blu ray.Yamaha YSP2200.Humaxt2 with hard drive.ArcamCD73 + A65 with B & W 603s3,Project something for vinyl + PC and CYP dac.
gbhsi1
gbhsi1's picture
I use a russ Andrews silencer block which should effectively do the same but no it doesn't...
Lost Angeles
Lost Angeles's picture
Does it hum without the earth connection?
__________________
Orbe SE.
chebby
chebby's picture
I can't quite remember what you are using as a turntable/arm.
If it's a Rega arm or turntable, have you tried disconnecting the earth lead to remove the hum? (Rega arms are earthed inside the arm tube so earthing between the Dino and the amp might create hum.)
Of course I could be entirely wrong. (No signature so I can't visualise your set-up.)
[Edit] 'Lost Angeles' got there first whilst I was typing the above and doing a search to try and find out what TT you use.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
gbhsi1
gbhsi1's picture
pro ject experience 2 turntable, 9cc tonearm.
gbhsi1
gbhsi1's picture
I'll try it without the earth cable....nope, the hum is still there.
Lost Angeles
How loud is the hum and is it louder or quieter or the same with the grounding wire discounted.
__________________
Orbe SE.
gbhsi1
gbhsi1's picture
it's only noticeable when I push the volume up to around 11 on the knob and gets loude if a turn up the volume further. it's the same with or without the earth wire connected...no difference.
fr0g
fr0g's picture
Try a couple of clip on ferrite cores on the mains cable. I had hum in my active speakers when the phone was about to ring, and this fixed it...
Something like these
http://www.amazon.co.uk/Split-toroid-ferrite-core-RKCF-13-A5/dp/B00412KMF6/ref=sr_1_2?ie=UTF8&qid=1330437383&sr=8-2
but make sure you get the size for your cable.
__________________
“Out beyond ideas of wrong and  right, there is a field.
I'll meet you there."
Lost Angeles
Is the hum there with the TT interconnect disconnected from the Dino? including the earth disconnected
Is the Dino new?
Was the hum there before you fitted the Rondo red?
EDIT  And try connecting the ground wire to your amp instead of the Dino or run an additional wire from the Dino to your amp Ground connection if it has one and see what result you get.
__________________
Orbe SE.
simon3102000
simon3102000's picture
Projects do hum unfortunately, one of the big problems with them from what i have read.... Has yours got the upgrade kit installed? This is meant to take away the hum but ive yet to try it, only £25 for the kit from henley design.
__________________
imac 2011, Airport express, DacMagic, NAD C326 amp, Wharfedale Diamond 10.1 speakers, Soundstyle Z1 speaker stands, chord cables, Tacima power conditioner. Controlled with my iphone 4S...
gbhsi1
gbhsi1's picture
upgrade kit? what's the upgrade?
Alears
Alears's picture
gbhsi1, I think he means:- The package includes: •2 Rubber Gromits and Screws •Rounded Drive Belt & Alternative Pulley See here:- http://www.henleydesigns.co.uk/product.asp?shop=0&ProductID=841
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Groove Anniversary/Tom Evans Vibe Preamp/Linear A power amp/Acoustic Zen Adagios/ Chord cables
gbhsi1
gbhsi1's picture
its doesn't say that it can be used with my turntable xperience 2?
