how to safely remove wires from cartridge to change to new cartridge?
2 replies [Last post]
simon3102000
simon3102000's picture
Hiya, well ive finnaly got round to ordering a new cartridge for my project debut 3 TT after a year and a bit of using the factory fitted jobby, ive gone for the ortofon 2m red as this seemed like the obvious choice. Ive read up alot and i am confident i will be able to insatll it and align it all up properly put my main concern is those 4 wires that are connected to the cartridge, man do they look fradgile! Do any of you have any pointers on how to remove them safely or is it just a case of gently does it? Would using tweezers be a good idea or should i use me fingers? Cheers.
__________________
imac 2011, Airport express, DacMagic, NAD C326 amp, Wharfedale Diamond 10.1 speakers, Soundstyle Z1 speaker stands, chord cables, Tacima power conditioner. Controlled with my iphone 4S...
Andrew Everard
Andrew Everard's picture
RE: how to safely remove wires from cartridge...?
Tweezers or jewellers' needle-nose pliers. And gently.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
gbhsi1
gbhsi1's picture
RE: how to safely remove wires from cartridge to c
Whatever you do, DON'T use your fingers Smile
